Question about Bosch 24 in. SHX46A05 Stainless Steel Built-in Dishwasher
I have a Bosch SHX46 which keeps tripping the circuit breaker. It trips the circuit breaker with the bottom of the dishwasher full of water. I remove the water by hand and reset the circuit breaker, but it seems to trip and the same time in the cycle. I believe that this model has two separate motors, one for dispensing water, and one for draining. Could this mean that there is a problem with the motor that drains the dishwater?
  • DILLIGAF
    DILLIGAF Mar 14, 2011
    At what point in the cycle is it tripping and is it tripping a circuit breaker or an RCD? An RCD detects a short/leakage to earth and will have a TEST button and a reset switch/lever. A circuit breaker trips when there is a short between hot/live and common/neutral and will only have a reset button.
  • j_fonteno677 Mar 14, 2011
    It seems to happen at different times, because sometimes the dishwasher liquid gets dispenced and sometimes it does not. It is tripping the circuit breaker which only has the reset switch.
SOURCE: Bosch #SHU9955 Integra dishwasher for
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Posted on Oct 12, 2008
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
cjrepairs
  • 60 Answers
SOURCE: bosch exxcel
either element or probably a leak on the wiring important to get this checked.
Posted on Aug 16, 2009
  • 49 Answers
SOURCE: Our Bosch dishwasher will not turn on. It appears
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
Posted on Aug 20, 2009
  • 142 Answers
SOURCE: shu6802uc Bosch Dishwasher trips house circuit
poss heater leaking to earth.
Posted on Sep 28, 2009
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
Bosch SRS53C02GB/27 tripped circuit fuse, Changed plug fuse still no sign of life
Has the circuit breaker / fuse in the meter box tripped or blown as well? If the machine tripped or blew a fuse, it is common for the heater element to be the cause or you have a water leak internally and its shorted something.
Mar 01, 2015 | Bosch Dishwashers
Bosch classic dishwasher
Circuit breakers do fail. You could swap a different 15amp breaker from another circuit to test this hypothesis, or just swap it with a new one. At least this way you'll know it isn't a power supply issue.
Feb 17, 2014 | Bosch Dishwashers
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
I have a bosch dishwasher model # I believe is SHX4AP05UC it keeps tripping my braker in the middle of washing wont complete a cycle any suggestions?
Adam, in order to help you, you must provide me with more info. What size breaker is tripping. What does the maufactor's manual reads about what size circuit it must be plugged into. If your house is a little old you probably have a 10 amp breaker that is tripping. If so than the manufaturer states theat it is recomamded to place it onto a 20 amp breaker. Only switch out the 10 map breaker to a 20 amp breaker if your the wire from the breaker is a 12 gauge wire.
Do not put a 20 amp breaker onto a 14 guage wire because it will most likely melt the insulation due to heat whichwill expose the bare copper wire which could lead to burning your house down.
Dec 02, 2009 | Bosch Dishwashers
Dishwasher is "tripping" the breaker & not draining.
Jan 08, 2009 | Bosch Dishwashers
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHX46A05 Stainless Steel Built-in Dishwasher Logo
292 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
