Question about Kenmore Dishwashers
All of the water is not going out. - Kenmore Dishwashers
  • 827 Answers
Clear the drain at the bottom of the inside of the washer.
If already done, then you may have a plug in the drain line - remove, clear, inspect where the drain line goes into the drain at the end first, and replace drain line..
Best regards
Ck
Posted on Mar 14, 2011
WATER HEATER WAS LEAKING FROM BOTTOM OF TANK, I SHUT OFF WATER VALVE, AND SHUT OFF PILOT IS IT NECESSARY TO SHUT OFF GAS LINE GOING TO HOT WATER HEATER HAVING A NEW ONE INSTALLED TOMORROW
Yes, you have to shut off the gas going to the water heater. There should be an inline shutoff around it. Otherwise your going to be leaking a lot of gas which is very dangerous.
Apr 03, 2016 | Water Water Heaters
Way is my water softener has salt taste in the water after regeneration
Mine done this, found the water lines going into the softener was hooked up backwards. Make sure the water source is going in the directions the arrows on the valve are going.
Oct 29, 2015 | Water Dispensing & Filtration
Water is going to the water dispenser but none to the ice maker, why?
The valve cpuld be bad or water has frozer in the water tube that fills the icemaker. This is fairly common.
Sep 11, 2014 | Whirlpool Refrigerators
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Water in door dispencer but no ice cubes in freezer
Remove the water line in the back of refrigerator going into the ice maker - its likely the line froze. Once thawed (about an hour) put the water line back on and cycle the ice maker - you should hear the water go into the ice maker.
Dec 17, 2013 | Refrigerators
E10 error code on Frigidaire affinity how to repair it
Your fill time, water fill time, is too long. Have a professional complete the following:
. Is the incoming water flow normal? Yes, go to step (4). No, go to step (2). 2. Are the incoming water faucets turned on? No, turn water faucets on. Yes, go to step (3). 3. Is the incoming water pressure above (30) psi? No, have customer correct pressure problem. Yes, check for kinked or blocked incoming water hoses, clean incoming water screens. If problem still remains, replace the water inlet valve assembly. 4. Does the fill water continue to enter the washer? Yes, go to step (5) no, go to step (6). 5. Remove power from washer. Did the water fill stop? Yes, go to step (6). No, replace the inlet valve assembly. 6. For Better models, check the electronic pressure sensor. For Good models, check the pressure switch. Pressure sensor checks good. Go to step (7). Pressure sensor checks incorrect. Replace pressure sensor. 7. Replace the Main Control Board
Aug 16, 2012 | Frigidaire Affinity ATF7000ES Front Load...
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
Older kenmore fridge. Ice & water dispensing not working.
Yes water valve can go bad. Can you post model # and can get you a manual.
Mar 02, 2010 | Refrigerators
When start just runs with no water
its hard to know exactly what is the problem withot knowing make and model,
here are some water tips.
1.check that water going into the machine.
disconnect the water lines going into machine to see if there is water.
2.if there is water then your water valve is the next step. check the water valve with a ohm meter if the water valve is bad then no water will go into the unit,
let me know if my info helped you
Feb 23, 2010 | Dishwashers
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
Dishwashers Logo
41 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
