Question about Casablanca Fan 6645A Panama Brushed Nickel Ceiling
This is the third time since the fan was purchased (10/2009) that the controller has stopped working. I have turned power off, taken the batteries out, reset the pins, put the batteries back in, turned the power back on, and held down both buttons. The lights come on the controller but the fan itself is no effected. I purchases three fans at the same time. I am not having the same problem with two of the fans - only one.
  • 3,640 Answers
Check out this site, it may help you out. www.eceilingfans.com/remote_controls_faq.html but it really seems like the receiver in fan is bad.
Posted on Mar 14, 2011
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Flat battery every morning even though I make sure all accessories are off, heater fan not turning off all the time when ignition off
With hot battery, turn all off, wait 10 minutes and then feel of all relays to see if one is warm or hot. Stuck relay can cause this.
Feb 13, 2015 | 2003 Mitsubishi Outlander
Cooling fan stays on after turning off car
Taken from other previous solution (but it's right): the cooling fans are switched off and on by a relay. either this relay bad and staying on all the time, or something else is bad and telling it to stay on all the time. you might unplug the engine coolant temp sensor and see if the fans switch off. if they do you have a bad temp sensor, if they don't you probably have a bad relay. they will test either for you at most car parts stores. the relay will be in the underhood power distribution box, it plugs in like a fuse. disconnect the battery negative terminal before you start unplugging things from the power distribution box. hope that helps
Apr 02, 2014 | 1992 Chrysler New Yorker
I have charged it and i still cant get it to turn on.
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 05, 2012 | Computers & Internet
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
1995 Mercury Grand Marquis electronic Dash goes blank
Possibly bad wiring with the tow package added on. Almost like it was not installed properly or that the lines where crossed or it was setup to a wrong fuse and it is popping eveything and making this happen
Feb 19, 2009 | 1995 Mercury Grand Marquis
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
LH_D6230
The spin motor is in short !!!
Nov 17, 2006 | LG LH-D6230 System
Casablanca Fan 6645A Panama Brushed Nickel Ceiling Logo
117 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
