Question about Refrigerators
Have 16 yr old Kenmore model 106.9537622. The heater strip at the center divider between freezer and frig gets real hot for a period of time everyday and causing frig and freezer to be too warm. The strip has a hot spot about half way between top and bottom. I was appliance repairman 30 years ago but could not find wiring diagram on frig and having trouble getting trim off to get at controls or strip heater.
  • 481 Answers
If this is a side by side refrigerator, then the space between the doors is not heated by an electric heater. it is heated by part of the condensing coil. so the excess heat is probably generated by a loss of adequate airflow under the machine. which would explain the temperature change in the refrigerator.
  • clean the coils under the machine and make sure the fan is working.
  • make sure the airflow is not obstructed in any way.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 01, 2008
Gasket between frig and freezer is darkening due to very hot surface on divider between sections
If it is that hot you really need to get this checked out ASAP. It could become a fire hazard.
Mar 12, 2014 | Admiral Refrigerators
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Jul 18, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Side by side is HOT between fridge and freezer. I know there are alot of comments on how to check the coils but I don't understand how... I checked the toe kick area and I don't even see coils......
THE ONLY THING HOT IN FREEZER IS DEFROST HEATER AT COMES ON EVERY 6 HRS. FOR 20 MINUTES, YOU CAN PULL THE FRIG. OUT AND USE A 5/16 OR 1/4 INCH NUT DRIVER TO REMOVE CARDBORD,YOU WILL FIND CONDENSER FAN AND CONSENSER COILS,USE HAND BRUSH AND THEN A SHOP VAC TO REMOVE ALL DUST,YOUR FRIG. WILL WORK ALOT EASYER NOW,THANKS-MIKE
May 29, 2008 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
