Question about Durabrand PDV-709
Pdv battery problem
Charging batt, does not work.red light continues to flash after several hours of charging.
Were can I buy a house and car charger for this dvd
Posted on Aug 03, 2008
What does flashing red lights on the charger mean
Red lights on the charger means it is still charging.
Jun 28, 2014 | Parrot AR.Drone 2.0
I bought a second battery (standby as I am going to Africa) for my Inspiron, charged it for about 10 hours until it indicated it is full. However, the power light has been flashing red since. Even when I...
Flashing red indicates that the battery is non-functioning (at the end of its ability to hold a charge), although as it is a new battery, this would seem a bit odd.
Did you buy the battery new or 2nd hand, was it a genuine Dell battery? My suspicions are that if this is an aftermarket battery and one which was not compatible with the dell, then there might have been some damage done to the laptop, causing the old battery not to charge. I'm assuming you are using a genuine Dell charger
Jun 21, 2012 | Dell Inspiron N5030 Notebook PC
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Casio Exilim battery won't charge
What model of camera? You will probably need to purchase different battery.
Mar 18, 2008 | Casio Exilim EX-Z40 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Durabrand PDV-709 Logo
43 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
