Question about Telex Radio Communications
I have a Telex Headset PH 88 (4 pin female) and I would like to use this headset with a BTR-800 B4 unit which has belt packs that accept 5 pin female. Do you have any suggestions?
    Top Expert:
  • Telex Master
  • 74,482 Answers
Hello
You can't use it. The wiring scheme is different to each other. OK.
Posted on Mar 14, 2011
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
For headset use - phone has a female rj-11 connection - the headset I am using has 3.5mm male connections for speach (mic), and for earphone. Do you have an adapter than can accomodate - male RJ-11 to...
First, we want to clarify that the headset connection is an RJ9 (RJ11 is the phone cable to the wall and the clip is larger). Plantronics doesn't make any such adapter but it is available online, just type "converter rj to 3.5mm" and you should get some leads to check out.
Good luck from Headsets Direct - 800-914-7996.
Aug 15, 2011 | Plantronics Headset Telephone Headset
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I has sony ericsson blue tooth, my phone is nokia E72 how to connect?
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect:
1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity.
2.in that switch blue tooth on.
3. now go to the next tab, and select options. from that select new paired device.
4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on.
5. then select that headset fro the search result and then it will ask for confirmation with the pic code.
type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working!
Thanks, ask me if u gt any doubts.
Oct 06, 2010 | Cell Phones
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Telex BTR-500 Instruction Manual
I have a manual I can fax to you if you are interested. Email me your fax number, or e-mail address and I'll scan it. Send to: diann_sells_slah@yahoo.com.
Jul 26, 2008 | Telex Btr-500 set (71208000sp) Wireless...
Telex H-551 Digital USB Headset and Audio/Microphone
Call 1-800-898-6723 x 1 (if outsidethe USA call using SKYPE. It is free to call USA toll free numbers using SKYPE.
The driver is the same for P-500. It is about 14KB in size.
I got mine today from TELEX. It is 01:11 July 29, 2008, Indian Standard Time.
Best regards,
Randy.
Dec 23, 2007 | Telex H-551 Consumer Headset
Jabra ear piece
Call the Jabra Support hot line they will send you replacement earhooks free
Takes less then 5 mins to get them sent
Sep 30, 2007 | Jabra Bluetooth Headset with Adjustable...
Radio Communications Logo
316 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
