Question about Dell Computers & Internet
I just install a new dell inspiron 1721 motherboard. i used my friend 19.5 volt dell adapter to test it, however the led light goes out went plugged into the laptop only.
  • 81 Answers
The laptop has a big consumption and you can destroy the power adaptor. Make some measurements before to connect it again( if it is still good)
Posted on Mar 14, 2011
M5010 - Tested DC Jack (PC wont turn on at all) and i noticed it shows 1.7V instead of 1.9V Is it bad?
The Dell Inspiron laptop mains adapter output voltage is 19 volts.
If your adapter has an output voltage of 1.7 volts then the adapter is faulty and you need to purchase a new one.
Feb 25, 2012 | Dell Inspiron 15R Notebook
Dell D810 Laptop wont power on. Have brought 2 new ac power adapters. They work (led light on power adaper goes on), but when I plug them into the computer the led light on the adapters go off. Computer...
HELLO FRIEND, THE PROBLEM WITH THE LAPTOP IS QUIT A MINOR ISSUE BUT YOU HAVE TO DO SOME SOLDERING WORK ON THE COMPUTER. THERE'S A POWER SUNG ON THE COMPUTER WHICH HAS TO BE SOLVED BEFORE IT CAN WORK WELL, AND STOP THE LIGHT OFF PROBLEM.
Jul 30, 2011 | Dell Latitude D810 Notebook
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
Feb 15, 2011 | Dell Inspiron 1721 Notebook
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
Battey not charging, red light flshing
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 1525 Laptop
My dell inspiron will not turn on. I press the power. the power light flashes for a sec. I hear a quiet click then it goes out.
hi,
-please try to run the diagnostic on the computer
-while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; if computer powers down after the test initialize; it is a possible motherboard failure
-to conclude that it is a motherboard failure check the lights on the laptop, it the lights flashes then computer goes off; it is a motherboard problem
-in addition try to do the test while computer's battery is out of the computer
-thanks
Sep 24, 2009 | Dell Inspiron 1721 Notebook
My Dell Inspiron laptop won't power up. There are no lights AT ALL. It worked when I left for holiday. I have bought a new AC/DC power unit: just the same. The green light comes on when I plug the AC/DC...
If the light on the A/C adapter "goes out" when you connect it to the Laptop... then your motherboard is bad.
Your motherboard is "shorting out" the A/C adapter, in which case you will need a new motherboard.
Sorry....
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Power port issues as well
Must solder loose connect. Need you take it to good pc tech, or have steady and be electronically inclined.
But, first you check to see if adapter is fully working. The adapters have two current flows, is positive 19 volts, and negative -19 volt. One can die, and the other works. In my case, the 19v that powered my laptop worked. This happened to me twice.
The best way is to use multimeter but this involves taking the adapter apart. The easiest way is test it on another laptop that work correctly. Let the laptop powered by battery stay on for a couple of minutes then plug you adapter in, and if charge light blinks on your adapter is okay.
Laptop must almost completely taken apart, down to the motherboard and loose plug connection should carefully soldered.
Aug 14, 2009 | Dell Inspiron 6000 Notebook
Computer will not start
In my opinion, if the motheroard is dead and it is an older laptop, it is now spare parts. BUT first, try another power adapter to make sure that is not the problem. You do not want to replace the motherboard with the same one, you should want to upgrade the MB. But laptops are one of a kind deals where a newer, better MB just won't fit. So after you have checked to make sure it is not something simple to fix, consider a newer laptop.
May 25, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 1501 will not turn back on
Hi Melissa,
The battery is OK, when you press the test button the number of LED that are on indicates how much charge is in the battery.
When you plug the adapter into the laptop there should be a LED on the laptop that indicates that it is on main power and charging.
You fault appears to indicate that you have either faulty RAM (memory) or it is not making proper electrical connection with the motherboard.
The RAM is located on the bottom of the laptop under one of the panels. Remove the panel and reseat the memory modules (take it out and insert it again a few times), the reboot your laptop.
If it still doesn't work remove it and take it to your friendly computer shop and get them to test it in another laptop, if it is NBG (no bloody good) then you will need to buy new memory.
Best of luck.
Dec 30, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
55 people viewed this question
Alun Cox
