Question about AOpen MX4GER Motherboard
Motherboard not boot. i change ram cpu p/s but not boot
  • AOpen Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Posted on Mar 14, 2011
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
Plug power cord in to computer, power supply starts up system fan and cpu fan starts and runs no other indication that the computer is booting up. this happens with all cobles diconnected, even the frount...
Try swapping out the RAM first since it's easier then changing out the CPU. If that doesn't work, then the probably most likely lies with the CPU.
Regards,
Matt
Mar 30, 2011 | HP Computers & Internet
P4M800Pro Intel Pentium 4
Sounds pretty much like a motherboard problem. The problem you describe sounds like a RAM problem, probably they are loose in the slot or not snuggled properly. However, since you seem sure its not the RAM, I would consider replacing the motherboard.
Sep 30, 2009 | Biostar P4M800-M7A Motherboard
Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
post a coment if this does not work.
thanks,
wonder
Sep 18, 2009 | ASUS P5VDC-MX Motherboard
Display problem
Problems can be more than we almost can list here.
Check the cpu that it will work in another board.
Check the ram modules that they will work in another board.
When checking the board, remove all cards and try with the cpu and ram installed. Make sure you have the right ram in the right slots. This can make a diff. in some boards.
If your processor and ram are okay, then a problem is existing with the board.
Sep 08, 2009 | Asrock P4I45GV R5 Motherboard
PC not even booting...
you might have fried your PSU
Apr 11, 2009 | XFX GeForce FX 5500 Graphic Card
Acer 3100 boot freeze
boot frozen you may try
1) change RAM memmory or change the memories slot between one and another
2) check cpu fan works when booting
3) clean the dirty stuff through the way of cpu fan
if not fix, your motherboard hardware need to repair by the specialist
Jan 24, 2009 | Acer Aspire 3100-1405 Notebook
Elite Group K7S5A Pro Monitor Not Responding
you need to take every ram, board and cable out of place... then clean it all perfectly... (isopropilic alcohol is the best to use in cleaning hardware) then reconnect it all and just try powering on with just motherboard, cpu and ram, NOTHING ELSE... if the system starts... you must connect all pieces, one by one, booting the system after includding each thing to isolate the problem if there is one... after all peaces are back togeter, test the system normally.
IF MOTHER does not boot only with cpu and ram... you have hardware problems either in mother, ram or cpu or power supply and you will need to replace hard... good luck
Mar 21, 2008 | EliteGroup K7S5A Pro Motherboard
Motherboard problem
start troubleshooting by unplugging everything from motherboard, leaving only power supply, motherboard, cpu, memory. also check make sure cpu fan/ heatsink assembly is attached securely and if encounter no problem booting like this, add harddrive, repeat, then add optical drive, repeat.
also when you check hardware monitor, what do u get for readings, i.e. temp and voltage?
Oct 28, 2007 | ASUS P5P800-VM Motherboard
AOpen MX4GER Motherboard Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
