Question about Microwave Ovens
Professional series Starbucks coffee machine tells me to "Service Water Filter" We have replaced the cartridge filter unit at the back of machine and it still displays that same.
  • surfblu Mar 14, 2011
    I would be happy to help. Can you please provide the model name or number of your Starbucks coffee machine? Thanks!
  • ray_genier Mar 14, 2011
    Yes it's a "CAFECTION" model#SB10301
4 Suggested Answers
  • 10865 Answers
SOURCE: can u please tell me
Hello. This will be a trial and error situation. Increase the scoops of coffee to 7 and see how it tastes. If it is still a wee bit weak at 7, jump it up to 8. Joe
4 thmbs up please. Thank you.
Posted on Oct 15, 2010
  • 5370 Answers
SOURCE: Sunbeam Cafe Series EM6900 Yesterday
Remove the black plastic thing from the filter basket.Check if that is cracked or broken.If its broken replace it,other wise remove it and clean it internally also clean the head gasket.:---It is held in by a little retaining clip. To get it out without damaging. Remove the spout (use a screwdriver wrapped with masking tape so you don't damage the spout...then use the screwdriver to leverage off the spout). Once you have the double or single spout off...get in there with a screw driver and pop it out! See fig below:-- helpmech_72.jpg its purpose is to insulate the pouring espresso from the portafilter, keeping it hotter. -------------
Remove the retaining clip for the basket with the tine of a table fork - easy!
- Remove the spout - you can use a screwdriver to loosen the double spout.
- A techscrew driver bit will be useful,It just needs to be something hard and cylindrical you can hit with a hammer to knock the plastic liner out. A bolt with an appropriate diameter would work fine.
- Placed the group head upside down on the carpet (to avoid scratching it on a hard surface) and give the driver bit a tap with a hammer whilst holding it against the bottom of the plastic liner.. It pops out with the tiniest of taps (and undamaged )
This is how dirty it gets/.Remove this and clean it and also check if its damaged:--See fig below:--
Try this cleaning and checking.This will help.Thanks.Keep updated.Helpmech.
Posted on Feb 11, 2011
  • 910 Answers
SOURCE: I have purchased a house
It's a Dual Stage Filter System and they're both activated carbon filters which is correct for this system.
Full Details, Manuals & Spares at the links below.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GNSV70FBL
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=ACCESSORY
If you need any further assistance just ask.
Cheers
Andy
Posted on Jul 12, 2011
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
Hello, I have a Delonghi Espresso Machine (EC 155). I bought it 17 days ago and I have used it twice in a day carefully. Everything was perfect with my machine until 3 days ago. Then I observed these...
Your machine is new and its under warranty you have rights to replace it with new one. Call your dealer where you brought it, it's either they will replace it or send a service technician.
It will void the warranty if you try to unscrew something.
I hope my advice gives you an idea regarding your unit problem.
Mar 29, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that,...
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
Mar 09, 2011 | Microwave Ovens
I need a new carafe for my starbucks barista aroma grande coffemaker
Starbucks has posted the following on their site:
All Starbucks Barista-branded espresso machines, brewers and grinders have reached the end of their time under warranty, and we can no longer support the replacement of defective parts or products. We're sorry for any inconvenience this may cause:
http://www.starbucks.com/customer-service/faqs/shop
You will need to find a replacement from a secondary parts supplier and may have to select a similar product from another brand.
You could look here for some possibles:
http://www.abtecparts.com/coffeemaker_parts.htm
Feb 20, 2011 | Microwave Ovens
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
Jan 08, 2011 | Hamilton Beach Microwave Ovens
Plastic ring is broken inside coffee pot - replacement lid or complete pot is needed for 12 cup barrista unit. Thanks.
I read in a web blog that Starbucks will send you the needed parts (for free) for the coffee pot if you contact them and let them know what your problem is. Here's their site:
Good luck, and hope this helps.
Nov 09, 2010 | Microwave Ovens
Can u please tell me how many desert scoops should I put into the filter / to how much water? I've been puting in about a litre of water and 6 scoops of coffee but it seems very weak!
Oct 15, 2010 | Microwave Ovens
I purchased a sunbeam coffeemaker in June from Zellars. I didn't start using it until the first week in September. I noticed that it dripped from the coffee grinds holder even when it had finished brewing....
Contact sunbean customer service. Look on the web for contact numbers. Explain your problem and tell them you have the reciept and have been contacting Zellars but have got no response. So you decided to contact them directly. Almost all the time they will honor your problem.
Nov 26, 2008 | Microwave Ovens
Microwave Ovens Logo
366 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
