Question about Jet 1HD Power Electric Wheelchair
On the Jet 1 HD on lights are on while charging. when electrical cord is removed, no lights and no power. can it be the batteries or charger?
  • 692 Answers
Batteries are not charging I would replace them. The charger is working because you have lights when it is plugged in. Hope this helps
Posted on Mar 15, 2011
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
No power
Try another outlet, cord/charger, with the EXACT same power specs. Has the cord plug been pulled while pluged in damaging the AC jack? Does the computer boot on battery power?
Feb 20, 2013 | MSI A6200-059US Laptop
Adapter from power cord gets power, but is not charging samsung rv511 laptop
Step 1:
b> If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 12, 2013 | Samsung Rv511
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I just purchased a used Jet 3 ultra power wheelchair...after charging it up I turn it on and the red light is flashing and it makes like a clicking sound when i try to make it go forward..cand you please...
bobby
The batteries are not charged. The red light indicates low batteries and the clicking sound you hear is the electric brakes being energized. Now the problem could be bad batteries or a bad charger. If you have access to an off-board charger (maybe a friend or acquaintance might have one) plug it into the charger port located under the front of the joystick. Don't plug in the on-board charger at the same time. Charge the chair overnight with the off-board charger and you should see a red light(power) and a green light(if the chairgot fully charged) if the light is still yellow then the batteries are bad and need to be replaced. Your chair uses 2 U1 batteries and if there is a battery store near you get them there. Interstate makes a good battery if you have a dealer near you. Hope this helps Good Luck
Oct 22, 2010 | Jet 3 Ultra Power Chair
I charge my jet 3 ultra with the cord but as soon as i remove the cord it dies what do I do? I no longer have the instruction manual
jaeger How long have you had the chair? And have you changed the batteries or had them changed within the last year? The problem could be the batteries. If the were run down or not charged for a long time then your charger cannot pick them up enough to reach a full charge or in your case no charge at all. Now if the batteries are fairly new but have run down the problem could be the charger. If you have a digital voltmeter and your Jazzy has an on-board charger -- plug in the charger then put the test leads in the charger port two outter plug holes under the front of the joystick set the meter to 200 volts dc. You should read up to 30 volts with the charger plugged in. Now unplug the charger and you will read the battery voltage it should read 24-27 volts. If when you have the charger plugged in and you don't read up to 30 volts then the charger is bad If after charging overnite and you don't read 24-27 volts the the batteries are bad If Medicare purchased your chair then you can call a service company to repair your chair and they will bill Medicare for the cost of the repair. Medicare will pay 80% of the cost. You can call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have a tech come out and rpair your chair. Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
I need to know how to charge a power wheelchair plse
You will need to connect the charger that was issued with the power chair to a working electrical outlet (do not use an extension cord or power bar/strip), turn it on and connect the other end to the power chairs' charging receptacle. Keep it connected for 8-12 hours or until the light on the charger indicates the batteries are charged.
If the charger indicates the batteries are charged but the charge does not last more than 1-2 hours, they batteries may have gone bad, are worn out and need to be replaced.
Aug 09, 2010 | Health & Beauty
Jet 1HD Power Electric Wheelchair Logo
76 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
