Question about HP Office Equipment & Supplies
We have a LaserJet 5500 in which a part is broken, no description or part number being available in service manual. It shows the part in figure 8-11 of the service manual, but no further information is provided, i.e. description or part number. It is a small plastic piece and is depicted in figure 8-11, being the part directly below the #5 sub-assembly. Can anyone please help? I have made phone calls in attempt to find a solution but nobody has been able to answer my question at this time. Thanks!
  • HP Master
  • 1,915 Answers
There are some parts that are just not available period. I work for an HP service partner and I have had HP contact me trying to find some of these unlisted parts. Your best bet is to try and find a dead unit you can buy for parts, or check with a local service center if they happen to have a 5500 sitting derelict that they will canibalize a part off of.
Posted on Mar 14, 2011
  • jeremy_conaw Mar 14, 2011
    Thank you. I unsuccessfully tried one local place but will keep looking.
HP LaserJet 600 M602 broken toner sensor?
Likely you need RM1-4539-000CN. This is a the tag holder assembly.
Jul 22, 2015 | HP LaserJet Enterprise 600 M602n Workgroup...
ERROR CODE 51.2M
Hi
A quick look on the internet told me that this is probably a HP ColourLaserjet series printer/copier, and have proceeded on this basis using the 5500 model. This particular code crops up on several models and the explanation is given below:
Description:- A printer error has occurred.
X Description: 1 scanner error 2 scanner startup error 3 scanner rotation error Y Description 0 no color K black C cyan M magenta Y yellow
Remedy:- 1. Press GO to continue. 2. Turn the printer off and then back on. 3. Reseat the connectors between the laser/scanner (J74 - J77) and DC controller PCB (J1106 - J1109). 4. Replace the defective laser/ scanner assembly. Calibrate the printer after replacing the laser/scanner. 5. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
I obtained this from the link below:-
Error Codes HP Color LaserJet 3550 Code 51 XY
for the 5500, but there are drop down menus above the error details which enable you to change the model number to your specific machine and then you will get the exact requirements. I recommend you do this as although the error code description for other models is the same, the PCB numbers under the "Remedy" are different for different models. You can also download a service manual from this site using the link at the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Office Equipment & Supplies
Please sir, I need the service manual for hp laserjet 1300 printer
If you need service for your hp printer. you may visit HP Customer service or dial toll free number- 1-800-585-2494. hope this will help you better.
Jun 10, 2014 | HP LaserJet 1300 Printer
My Singer Fashion Mate 5500 is beeping and giving me an E6 message when I try to start sewing. Any idea what is causing this?
you can get a manual at singer in pdf form for free
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 5500 ) & click search
May 09, 2012 | Singer Sewing Machines
I need a manual for a singer fashion mate 5500
Go to the home page
if search doesn't come up with anything contact singer customer service
Mar 05, 2012 | Singer Sewing Machines
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
How to open Hp P2055d laserjet cartrige
If you go to hp.com/support type in your product, open manual should show you pictures of step by step instructions.
Jan 03, 2010 | HP 645A Magenta Toner Cartridge (C9733A)...
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
I have a laser jet printer HP color laserjet 5500 and lately i have noticed an increase in the number of times i have paper jams problems.what could be the reasons?
Hi dwigling:
You may need a new set of feed rollers. Check you feed rollers in the paper tray and if they are smooth you need to replace them.
Dec 02, 2008 | HP Color LaserJet 5500 Printer
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
