Question about RIM BlackBerry 7100v Handheld
What is auto on/off for - RIM BlackBerry 7100v Handheld
    Genius:
  • 1,114 Answers
That feature is for holstering your BB. When you holster it, it will go into auto off mode, and when you take it out of the holster, it will auto on.
Posted on Mar 14, 2011
I have a woods model 50007/50027 indoor 24 hour digital timer. I can not set it to automatically go on and off... it either says... auto on or auto off and does not indicate auto by itself. the timer...
Click to Auto Off. The system defaults to Auto Off when you complete the programming. The instructions do not cover the two 'auto' settings and it is confusing if you hit the power setting without knowing.
Aug 17, 2013 | Woods Hardware & Accessories
How to download auto cliciker
go to the auto-clicker website and click "download"
Jun 09, 2012 | HP Computers & Internet
Mobile phone unlocking codes
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Jun 08, 2010 | Cell Phones
I have a canon fax jx-300. How do remove auto
Hey!Simply press the on/off button once and it will go from auto print off to auto print on!Good Luck!
May 03, 2010 | Canon FAX-JX200
JVC camcorder won't work inside at night anymore.
check the following in camera mode and the auto/manual switch set to manual:
exposure: set to auto shutter: set to auto or off agc: auto white balance: auto program ae: off gain up: auto display/bright: +1-+3
after all that, hit the auto/manual switch again to set the camera into auto mode, the new settings should sort you out.
Jul 28, 2009 | JVC GR-D290 Mini DV Digital Camcorder
In setup
Here are the settings.
The fine clock ratio stayed at 0.5 after I loaded optimized defaults.
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio ____________ [8]
Fine Clock Ratio ____________[0.5]
CPU Host Clock Control_ [Disabled]
CPU Host Frequency (MHz)__________ [333]
PCI Express Frequency (Mhz)_______ [Auto]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [Auto]
DRAM Timing Selectable_______ SPD __ [Auto]
Performance Enhance = [Turbo]
CAS Latency Time________________ Auto (7)
Dram RAS# to CAS# Delay_________ Auto (7)
Dram RAS# Precharge Delay_______ Auto (7)
Precharge Delay (tRAS)__________ Auto (20)
ACT to ACT Delay (tRRD)_________ Auto (4)
Rank Write to READ Delay________ Auto (5)
Write to Precharge Delay_________ Auto (10)
Refresh to ACT Delay______________ Auto (60)
Read to Precharge Delay__________ Auto (5)
Static tRead Value_______________ Auto (6)
Static tRead Phase Adjust________ [Auto] (0)
CPU/PCIEX Clock Driving Control [800mV]
CPU Clock Skew Control [normal]
GMCH Clock Skew Control [Normal]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [normal]
PCI-E OverVoltage Control_ [normal]
FSB OverVoltage Control___ [normal]
(G)MCH OverVoltage Control [normal]
CPU Voltage Control_______ [1.25]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: N/A
x C4/C4E State Support..................: N/A
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect___________________[Enabled] *Note* Must be enabled to flash from USB
Hope this Helps, Please Rate My Response! Thanks!
PREM
Feb 20, 2009 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Nov 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
RIM BlackBerry 7100v Handheld Logo
69 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
