Question about Refrigerators
1) motor type noise coming fron the freezer. could it be the fan?? 2) Should there be insulation padding attached to the bottom of the cooling fins at front of the refrig.? Please advise. Thanks
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Mar 19, 2011
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Right Door is making loud popping noise
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
It's making a loud running noise
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
I am getting a loud rattling noise. could this be my compressor
Jan 29, 2010 | Frigidaire Refrigerators
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
Fridge makes chirping noise
Some areas noise may come from:
Inside:
Whenever the refrigerator is cooling a circulating fan is operating to move air through the freezer and refrigerator. This fan can be found in one of several locations: For freezers positioned on top of the refrigerator the fan can be found on the back wall at the center of the freezer; If your freezer is on the bottom then the fan will be near the top on the back wall of the freezer; and if your freezer is on the side the fan will be on the back about 1/2 way up or near the top.
These fan tend to wear out over time and make a noise like a whistle or chirping sound. Open the freezer and press any switch. If the noise is louder with the door open the motor that operates the evaporator fan is likely the cause. This fan cannot be serviced in any way and must be replaced.
The back of the refrigerator:
The compressor, defrost timer, or the condenser fan motor may be the cause of noise from the back. The compressor is located near the bottom and is identified by it's small black case that appears to have no moving parts, but several colored wires coming out of it. If you find the compressor is what is making the noise then you will have to replace it in order to get the noise to stop, these aren't serviceable (and can be expensive). Near the back of the refrigerator you'll also find the condenser fan. Sometimes this fan gets clogged with debris and can make a lot of noise as a result. If this is the case then simply clean the blade with a soft bristled brush, you can usually get one of these brushes from a hardware store, or you can order it from us by calling our 800 number. If it doesn't need to be cleaned then the whole motor may need to be replaced.
The defrost timer is usually found behind the kick panel. The timer has an electric motor attached to it that may become noisy over time and will need to be replaced in order to get it to be quiet again.
The bottom of the refrigerator:
Sep 21, 2009 | Refrigerators
Loud clanking noise when washer is coming to a stop
May 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
