Question about Sony Televison & Video
42" Sony Wega. After about
  • helidriver78 Mar 14, 2011
    I will try the solution offered and let you know. Thanks
    Top Expert:
  • Sony Master
  • 75,311 Answers
Hello
There are two main resons for this type of trouble with Sony. The first one is as you said, video card IC overheating. The second one is most common, and should be noted. There is a suupply voltage goes to video output card, usually about 270VDC, whcih cupplies ot video output section, and in turn drive the cathodes of the tube. If this voltage track has some trouble, that is, any loose soldering with any lead connections of the serial resistors, will cause very low voltages athe chatodes of tubes. From your post, I assumes this and might be. Check for any loose solderings in the video output cards.
Normally, loose soderings are hard to detect, as they will be microscopic. The easiest way is to resolder most of the suspected pointw by applying a little more solder, without shorting the adjecent solder points. do this first. Surely this process will solve your problem. OK.
Posted on Mar 14, 2011
My grand wega 42" rear
call sony. they have been offering new tvs at a discounted price for that problem. whatever they offer take asap. yes its a throwaway tv. sony the only company that is helping customers with that problem, other manufacturers say tuff. 18002822848.
Mar 22, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
Nov 02, 2009 | Sony WEGA KZ-42TS1 42 in. Plasma...
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony wega 42 has red dot on screen.
Is the dot in just one location..if so does it ever change color at all. My first guess is something has gotten into the color display, like a small dust spec. . Or there is an issue with the front panel. If the unit is less than five years old they will look at it on site under warranty.
Jul 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV turns on for about 5 minutes then shuts off.
The projection lamp is out and needs to be replaced.
Jan 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Aug 11, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
