Question about Maytag Refrigerators
10 year old Maytag USA style fridge freezer. Motor running all the time but freezer showing only 0 degrees C and fridge 15C
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 01, 2008
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
Why do both fridge and freezer stay at 50 degrees?
Can you provide the correct model number? Thanks that will help me see what controls your model has. I am here if you need me, Thanks John Tripp Appliance 911
Jul 30, 2014 | Maytag Refrigerators
Maytag MSD2456GEB fridge section warm
Please remember I am attempting to diagnose your appliance without being there and with very little information.
Sorry but if your freezer is 10 degrees, it is running warm. Freezer is designed to run between -10 and 0 degrees. Reset controls, place them in the middle of the scales. The controls can be confusing. The control that turns the unit on and off is your freezer thermostat and the other is the damper that controls the air flow from the freezer into the fresh food section. What I would think is wrong with your unit is one of two things.
  1. You have a defrost problem.
  2. Your inside fan is not running.
1. Look at the inside back panel of your freezer. If you have ice or frost built up on the panel, you most likely have a bad defrost heater.
2. Check to be sure you have air flow inside your fresh food section coming from your freezer. If not and your control is setting around mid-ways, you have a bad fan or your defrost heater is bad and ice is blocking the air flow.
Please rate solution
Sep 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
GE Side BY Side keeps Running
two reasons I can think of, fan motor because of the whining description you descibed, and possible freon leak. I think the first is the problem!
Dec 27, 2008 | Refrigerators
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Freezer warnm up
It does sound like the normal defrost cycle. Aslong as it stays at an average below 12 degrees it is normally working fine. Check to make sure the back air vents and front grille are clean and the fan by the compressor is running when the unit is on. It has to get rid of the heat so it will freeze.
May 16, 2008 | GE GBS18KBM Bottom Freezer Refrigerator
Refrigerators Logo
48 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
