Question about Garden
I have a Dremel multi max that will not start when plugged in.
2 Suggested Answers
  • 90 Answers
SOURCE: I have a dremel multi-max. It was a display. I
try tool parts direct, they list dremmel.
Posted on Aug 31, 2010
Dremel multi max stops when pressure is applyed
I took mine apart due to the same reason. Seems like the yoke that fits over the drive bearing is worn or bent to oversize so that it doesn't make a complete rotation. Hence, a very small or no cutting swath. You can replace the drive head for about 22 bucks plus shipping, (dremel parts) or go to Home Depot and get another one for 70 bucks plus tax. Or do as I did and go to harbor freight and get a Chicago Electric multi tool for about 30 bucks. It works fine. I'm not a professional and don't need a 200 dollar one.
May 07, 2014 | Dremel Multi Max Kit
My Dremel max won't start
Check and replace brushes as necessary. Also, check that the actual electrical switch is functional. I had to add a drop of crazy glue on the tip of the interior plastic handle housing that supports/puts pressure on the electrical switch to keep it in position. The off/on thumb slider actually extends well into the housing and activates the electric switch by moving back and forth. Over time, the plastic wears and does not plunge the on off switch button. A drop of glue on the tip of the plastic post extends it & causes enough pressure to make the electric switch to function again. Brushes (filed to fit) and glue = good as new Dremel :o)
Dec 08, 2012 | Dremel Multi Max Kit
Attatching dremel blade
You can't attach this to a Dremel Stylus. This blade is specifically for the Multi-Max tool. A link is below.
http://www.dremel.com/en-us/Tools/Pages/CategoryProducts.aspx?catid=2094
Oct 21, 2012 | Dremel Multi-Max MM462- 1 3/8 inch BiMetal...
My multi max stopped running in middle of my project
call 1300 307044 aus for replacement it may be falty
Jun 03, 2012 | Dremel Multi Max Kit
Dremel MultiMax 6300 has stoped working Will not turn on.
Mine died also. It's the on off switch. Where can I get parts?
Oct 27, 2011 | Tools & Hardware - Others
My dremel is always in max speed
The most likely culprit is the speed potentiometer. Poor design causes vibrations on the printed circuit board. This induces metal fatigue in the potentiometer terminations at the board. Eventually one or more terminals snap off. If you are a whizz with a soldering iron you could remove the pot and then solder a new wire/s onto it and fasten it back onto the board?
Dec 09, 2010 | Dremel Multi Max Kit
Can I buy a new cord for my dremmel multi max? my dog chewed it up and can I order it?
If there is one ck with (ereplacementparts.com) you will need your mod. # good luck
Nov 28, 2010 | Dremel Multi Max Kit
Apr 19, 2010 | Dremel Multi Max Kit
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
