Question about Amana 3.2 cu. ft. Top-Load Washer
Main tub bearing leaks on amana dlw330raw washer
Jimster
  • 240 Answers
SOURCE: main seal
This is a pretty tough job to do on your own, but can be done. First step is to remove the front, then the top. Remove the rear cover plate under the console, and swing it out of the way. Unclip the top ring and remove the four suspension dampener straps, remove the top ring. Reach under the agitator, and pull up with force (dont hit yourself in the head or face with it, hurts for sure...) until it pops off (agitators on GE's just snap). Sometimes these can be a real bear to get off, so dont get discouraged. Sometimes you can put a peice of small rope or line under it and jerk it up. After you remove the agitator, you will see the drive bell. Remove the bolt on top of the bell, and once again, try to pull the bell up and off the shaft (once again, a real bear in some occasions, rope trick or puller also will work here). Once you remove the bell, the good part starts. Most of us repair persons have a special spanner tool for that nut your looking at. I believe it is a 1 7/8" nut. This nut is REVERSED THREADED, which means to remove you will spin it clockwise. These spanner nuts can be very, VERY difficult to remove. A lot of WD-40 and time. Most of the time you have to bang them off with that special tool and a hammer, but you may get lucky. If you do get that nut off, you can remove the inner tub. Be sure that the metal drive hub bolted to the bottom of the inner tub is completely tight all the way around. GE units have a very bad habit of those screws backing out and the drum getting loose causing major league noise. Now that you have removed that, you need to remove the outer drum. Remove the wires from the motor, etc. Unhook the 4 suspension rods and plastic clips by pulling the bottoms down (spring loaded) and removing them from the frame. Unhook the tub to pump drain hose, tilt the entire center section top towards the back, and swing the unit out from the bottom. Remove the outer tub by removing the hold down screws. Your seal will be in the bottom. Just pop out and replace. Here are some diagrams that might help you out.
Cabinet and Top:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=CABINET%2C%20COVER%20%26%20FRONT%20PANEL&titleID=00002&
Drum, Agitator, Basket:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20BASKET%20%26%20AGITATOR&titleID=00003&
Drive Componants, Suspension Parts:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=SUSPENSION%2C%20PUMP%20%26%20DRIVE%20COMPONENTS&titleID=00004&
Good luck, and let me know how it comes out, or if you need anything further. Good Luck!!!!!!
Posted on Feb 03, 2008
catriver
  • 878 Answers
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Posted on Feb 21, 2007
SOURCE: Haier Washer M # XQG50-11
Once you remove the rear access panel, you would see the main pulley on the rear of the outer tub. You need to remove that nut with a metric allen wrench. once the pulley is off, you can then remove the bolts holding the yoke in place. The Yoke and the bearings are available as a part assembly from haier. It is highly unlikely that you would need to replace the outer tub.
Posted on Mar 08, 2008
SOURCE: replace a belt on a amana dlw330raw
you flip the washer on its side
remove the screws on the side
take out the tub springs
remove the pulley
put the belt on bolt on the pulley
put the tub springs back hardest part in my opnion
replace the screws
test the washing machine
....it is no different than changing a belt on a car ....my best suggestion is that you take pictures at every step and stay organized...that way u can tell orientation of all the parts.
Posted on Mar 19, 2009
heatman101
  • 43501 Answers
SOURCE: Amana washer doesn't spin, model dlw330raw,
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
I have an Amama NAV5800AW washer machine and about a month ago every time the washer is on spin cycle it makes a VERY loud sound, and lately has been leaking water during the spin. Any thoughts.
The noise you are hearing is the main tub bearing. Water has been leaking past the seal and into the bearing causing it to rust.There is no lubrication on the bearing anymore and you are hearing the metal on metal grinding. You are looking at a costly repair of about $350. I hope this helps you out.
Feb 28, 2011 | Amana NAV5800AW Top Load Washer
Amana dlw330ra, loud and leaking
HI,
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 11, 2008 | Amana DLW330RA Top Load Washer
My washer keeps leaking grease onto my clothes!
the problem that you have is the bearings have badly worn,a lot of companys will just replace the entire drum rather than mess about with the bearings as this does not always solve the problem.sorry to give this bad news.
Jul 15, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Replace a belt on a amana dlw330raw
remove the pulley
replace the screws
Dec 28, 2008 | Washing Machines
Loud and leaky
Tub bearing replacement on ANY Amana (Maytag) can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 28, 2008 | Amana NAV5800A Top Load Washer
Amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
May 12, 2008 | Washing Machines
Leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at familyappliancerepair@yahoo.com
Dec 06, 2007 | Amana ALW480DA Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
367 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
