Question about Brother HL 6050 Laser Printer
Drum & toner were replaced and now the printer PRINTS IN CHARCOAL have replaced the drum and toner twice
    Habit-Forming:
  • 64 Answers
I assume "Prints in charcoal" means dirty printouts. The toner is not staying on the paper?
Sounds to me like a bad "Fuser Assembly" problem.
You can source one from:
http://www.precisionroller.com/fuser-assemblies---units-for-brother-hl6050d/details_38855.html?src=gbps
Hope this helps
Posted on Mar 14, 2011
How do I fix blurry print
Blurry prints can come from a couple of things. However with most issues relating to blurry prints on laser prints the following needs to be checked.
1) Is the paper damp - Try opening a new ream of paper and try printing to clear it.
2) Is the toner unit incorrectly installed or remanufactured with incorrect toner - Try replacing the toner cartridge.
3) Is the drum past it\'s use - If your machine has been reading drum near end or replace drum then it has reached or reaching maximum page count for the drum. Replace the Drum unit.
4) Are the reflecting mirrors dirty - Check inside the machine when you have the toner and drum unit out and see if you can see a narrow indentation above where the drum sits in the machine(Normally about 15cm long by about 8mm wide with rounded ends). Carefully clean this indentation with a lint free cloth.
Sep 05, 2014 | Brother HL5470DW - HL-5470DW Wireless...
Why is it when using black it only comes out grey on the far right side
remove toner and drum unit
remove toner
check to see if there is toner in the drum unit if not fill unit run 5-10 prints
replace dev roller
replace drum cylinder(opc)
Jul 14, 2014 | OKI C5150n Led Printer
My Brother MFC 7840W prints but has a faint copy of the previous paragraph about 3 inches below. I have cleaned the corona wire very thoroughly but still the 'ghost' printing on my documents. How do I fix...
Yes. The drum is most likely your problem. It is possible that it is a one time problem, which can occur if you print a very dark black page or image followed by a light gray page or image. If it has only happened once or twice try printing a different document to check it. If it is happening repeatedly, then you should replace the drum and instantly see it fixed. You can get a drum anywhere that supplies toner.
I hope this helps! Good luck!
Feb 28, 2011 | Brother MFC 7840W Printer
My printer prints but on the left side of the page the print is all faded going about one inch in. i just replaced the drum and cleaned the corona wire twice. please help
The toner powder is not evenly distributed or it sticked together, A light shaking the toner cartridge will the distribute evenly the toner. Maybe is it stock for a long period of time.
Jan 05, 2011 | Brother HL 5140 Laser Printer
Replaced Toner
open the cover, press the clear back button(or options) when it says replace drum? press *00
Mar 23, 2010 | Brother MFC-7220 All-In-One Laser Printer
Replaced fuser and toner units now only prints black pages
Printing on a laser printer has 3 steps:
1. electro-statically charging the "drum", at various tiny "pixels",
to identify where the toner-powder should be placed.
2. feeding toner-powder onto the charged drum.
3. making the fuser produce heat to "bake" the ink onto the printer.
So, a failing unit or failing electronics would "charge" *ALL* of the drum,
thus putting black ink EVERYWHERE onto the page.
Take the printer to a qualified technician.
Nov 13, 2009 | Epson EPL-N3000 Laser Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Brother HL 6050 Laser Printer Logo
113 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
