Canon IRC3100 colour copier machine error code
This machine appear ERROR CODE E000020-0081...i try to change drum cartridge and resetted but it still same ...could anyone help? thanks ya....
  • rafael vargas Dec 06, 2008
    I have the 0020-0080 error what color is causing the problem?
    what i need to do to solve it?
    Problem Solver:
  • 11 Answers
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Posted on Aug 07, 2010
  • 47 Answers
This is what this machine does best! :P
Since you have already had the drum out, pull it out again. get a small flash light and look inside. About half way inside, at about the 10 or11 o'clock position is a small sensor that shines on the drum. Take a cloth and wipe the surface and reassemble and all should be well. Note the colour of the toner wiped off the sensor, (it is most likely black) if the problem returns then the developer unit of that colour needs to be replaced. The black can be replaced by itself but the colours should be replaced as a set.
Posted on Aug 02, 2008
  • SAL Jul 20, 2011
    Beaker020...you're awesome dude. I had a service call into Ikon to come out and fix my problem (error code E000020-0081 on my Canon Imagerunner 3170i) when I happened onto this site and saw your post and I followed your instruction and the printer works fine now. Thanks for saving me a service call.
I want E000020-0081 error on a Canon iRc3100-please give me solution
Posted on Feb 15, 2012
  • 3 Answers
I had the E000020-0081 error on a Canon ir2570C. The beaker020's advice was helpful. This is how to pull out the drum unit in case you haven't done it before:
http://img229.imageshack.us/i/cexv9du.jpg/
Posted on Jul 07, 2009
E000070-0002
Posted on Jan 13, 2010
  • Mani Bobby Dec 26, 2012
    open the ibt belt clean the ibt belt in side w mark
E000020-0081
Posted on May 12, 2011
    open the drum unit and drum unit up sensior clean the sensior
Colour settings
Posted on Nov 17, 2010
Hello, When I switch on my iRC 3100 colour printer *** copier machine, I got error code: E0020 - 0493 in several times. Could you please explain the kind of problem?
there is a problem with the settings of your printer, you may wish to visit the canon website or go to canon service center in your area.
Jul 03, 2011 | Canon iRC3100 Printer
Ir 3100 colour xerox i faced master copy centre white lines
hai my name is aslam u will change thr drum unit or ITB unit
Sep 14, 2010 | Canon iRC3100 Printer
How can I replace the Canon IR3100CN Drum unit.
Hi, yes it is drum RELATED error, but before changeing the drum, clean the drum sensor. When you remove drum unit, inside of copier in drum unit place, from left side, uperr in the middle you have small sensor - Clean it!
Then try again.
If not tell me the exact error code eg. E 020 - 01A2 or?
It may be problem also in developing units.
Apr 26, 2010 | Canon iRC3100 Printer
Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Feb 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
Canon IR C4080i
The drum will either produce an error code of E000020 with multiple subcodes. This is time to change it. Also if your getting weak density or solid backgrounding of a particular color. These are all ques to change the drum.
Feb 05, 2009 | Canon iRC3100 Printer
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
4,145 people viewed this question
jasbo
jasbo
