Question about Yamaha Portable Keyboard
I have a Yamaha DSR-2000 keyboard (circa 1987) plays great but need to replace a couple of broken keys. Got the keys from Yamaha and attempted to replace but there is something funky about the spring-action. Can't figure it out. The keys are kind of limp without the normal bounce. There is a metal spring clip of some sort under the key which must have something to do with it but can't figure out how it applies the pressure. Thanks!
hamhm
SOURCE: keys not sounding as loud as others
Hi, BHOWDY.
Probably the best thing to do is call the Yamaha service center nearest you. I live in the Los Angeles area, and the Yamaha service center closest to me is in Buena Park. I called them on the phone and told them what the problem was, and they knew immediately what parts were needed and they shipped them out that same day.
The contacts that seem to wear out the fastest are the ones near the middle of the keyboard. On my CLP-170, it's the keys between middle C and the G above that -- probably no more then 4 or 5 keys. However, I ordered replacement contacts for all 88 keys because once you take the piano apart to replace the contacts, you may as well replace all of them.
Good luck, Howard
Posted on Sep 29, 2008
SOURCE: 2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
عزف
Posted on Oct 31, 2008
SOURCE: missing/non-working black key on keyboard
albania
Posted on Dec 03, 2008
SOURCE: How do I take apart Yamaha PSR-280 keyboard to clean keys.
There are 17 screws on the underside of the keyboard that need to be removed. The base cover can then be removed. This gives access to the keyframe assembly which can be removed.
Posted on Feb 08, 2009
SOURCE: Yamaha digital piano clp 170
1) Clean the circuit board contacts under the keys (where the strip hits). Use wd-40 first (for possible rust), then soap and water (for sugars--don't soak the thing though), then follow up with rubbing alcohol (to remove moisture)
2) Replace the rubber strip. (You will need to order this part from a Yamaha dealer). I tried cleaning this, and was able to get every key working again (by themselves), but it the strip wears down and you will get random notes when you play CHORDS. Ended up having to replace it. Now its 100% working.
Posted on Apr 10, 2009
HOW TO PUT BISS KEY DSR 990
Hi, Sorry I cannot understand the question you need answering. Could you let me know what problem you are trying to solve on your PSRE233.
Aug 10, 2015 | Yamaha Psre223 61 Full Size Keys Bass...
How to fix Yamaha PSR 400 dead keys?
Normally this would be from dirty or broken key contacts.
Apr 19, 2013 | Yamaha YPT400 61 Key Portable Keyboard...
Dgx 230 dc in connector bad
This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
If you need a socket Google :
Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
Yamaha W 7 keyboard problem I have a Yamaha W 7 keyboard. Every now and then when I play the note A left of middle C the note keeps replaying or re-hammering while holding the key down. This started a...
under the keyboard there is a switch for each key, try to clean it whit water and a smooth paper. I have Roland keyboards and it happens after playing a lot.
good notes
Feb 07, 2011 | Yamaha Portable Keyboard
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
I have a Yamaha S30, that has a couple of keys that play really loudly. No dynamics on 4 keys, just blast away, no touch sensitivity. I bought new in 2000, used at home and gigging. Very reliable until...
I have the same problem.The rubber panel that is used for touch sensitivity (under the keys) inside the case wears down in time. You can split it and shift parts but you eventually will have to replace it. This rubber panel is very hard to get. Good luck.
Jan 21, 2010 | Yamaha Portable Keyboard
One of my keys on my yamaha portasound keyboard is broken
Sounds like you have a great system,heres a link you can call customer support for a relacement key or a service locationkeyhttp://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail.html?CNTID=451442&CTID=205100
Oct 20, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
I want to replce a couple of broken keys on a
Not familiiar with the PSR 6700, HOWEVER on the Yamaha Tyros the keys stay with the baseplate part. Once the top cover is removed, there are screws holding the segments of keys. The keys on the Tyros are in segments. As I recall the black keys are in two individual sections.
There may be commonality between the synths.
The keys press on a sheet of silicon rubber domes that have conductive "pills" under them. The restoring force is actually from the dome itself. Two contacts per key! BE CAREFUL to align the silicon sheet when re-assembling.
Jul 28, 2009 | Yamaha Music
How doI open a Yamaha P120 to fix sticky keys?
I've had the very same problem twice so far. The only solution I figured is to simpy purchase an equivalent key (contact Yamaha service in your country for this) and to replace the broken one. The reason why the key doesn't work smoothly as the other one is not dirt therefore any cleaning won't help. The key is cracked deep in the place where it's attached to its 'axis'. So you'll need to remove all the screws and unmount the cover (it needs a sideshift to open once the screws are removed), be careful with the speaker wires. However you'll need firm moves anyway. Opening is tricky and gets me surprised anytime I do it so you'll need some courage :). Replacing the key is even more tricky. You'll have to remove the broken one by pulling it horizontaly (use some force, it's broken anyway). Placing a new key you'll need to uplift the 'hammer' and then slide a new one. I'm sure you'll figure it out once you see it with your own eyes (it's really hard to decribe but not so hard to do it). Hope you'll do fine. I haven't tried glueing the crack for I doubt it would work for long. Good luck!
Jan 28, 2009 | Yamaha Full-Size Keyboard
Yamaha Portable Keyboard Logo
336 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
