Question about Yamaha Boating
Have a Yamaha GP1200R. Been running fine until yesterday. Took it to river and got about a mile down stream and it shut down. I let it cool down, it fired up and went about 100 yards and shut down again. It did this several times. Do you have any suggestions. Thanks
  • 48 Answers
It sounds like it might have a bad coil. I have had coils do this on me in the past on a few motors. See if you can find another coil just to try it and it this is the problem then just buy a new coil and replace it.
Posted on Mar 15, 2011
When car gets to normal operating temp it shuts down will not restart until cools off
Not necessarily. There was a re-call on the cooling system a few years ago. Check with your mechanic about that. ------------------------------------------------------------------------------------
Digiprog3
Dec 20, 2012 | 2001 Dodge Intrepid
I have a Kenmore Dryer Mod#110 62722101. It will run about 10 minutes and shut off, after a cool down period it will restart but only run about 10 mins. Heats, fine, tumbles fine. A few days before this...
If it runs after a cool down period, then the high temperature limit is part of the cause. What is causing the high temperature limit to overheat is next.
Strong stream of air should be felt coming out the exhaust, make sure this exhaust air works or the burner part will overheat and cut out the flame/burner on hight temp safety.
With good exhaust air varified, the drying air operating temperature sensor needs to be checked, this cuts power to the burner. The sensor must open electricaly when satisified on temperature and should be properly mounted for proper sensing of temperature.
Bottom line: Check the hot air and its control
Jun 04, 2017 | Dryers
Yesterday i was driving when my car overheat light came on and i pulled it off to the side of the rode. when i popped my hood and looked inside it my upper radiator hose had a large rip in it. so i took it...
On refilling your cooling system with coolant you may have to bleed air from the system via a bleeder valve usually located on or near the thermostat housing. Fill the cooling system and then with the engine running open the bleeder until a solid stream of coolant is emitted for several seconds.
Jun 23, 2011 | 1998 Buick Park Avenue
1998 1200 Custom - We bought this bike in 2000 and it had hardly ever been ridden. We rode it for a couple of years, then parked it in the garage when we bought a bigger bike. A year ago we took it out...
I had exactly the same problem. It turned out to be the ignition module. The first time that mine failed it was exactly as you described.
What happens when the ignition module goes is the bike will run fine then when the motor gets hot it will shut down. Then it won't start again until the motor has completely cooled down. Then it will start, run rough, get hot and shut down again.
You will find the ignition module behind the round cover where the points are on older bikes.
There is an LED light on it that will tell you if it is working properly or not. But replacing one probably isn't a project that you want to take on yourself.
Unless you are completely confident with working on vital electrical components of your bike then I would suggest taking it to an experienced mechanic whom you trust.
Jun 18, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
Hi i have a wr400 99model and have just done an oil filter n oil change then i started my bike it all seemed fine until five minutes of the bike running the header pipe started to glow red i drained the...
All the wrf's,250 426 400 etc. WILL heat up and boil if they are left running without being ridden.They need air to be flowing over the radiator.1 minute can be enough to get them hot if the choke is used.You wrote that this happened after an oil change.Did you previously let the bike sit and run?.Check your air filter is clean as this can enrich the fuel/air ratio and create extra heat.Main thing is ,shut the bike down if you are stopping for more then a very short time.To satisfy yourself,take the bike for a slow ride as it is warming up.It can take up to 1 mile to get proper temp. into the entire motor.Hope this helps
Apr 24, 2010 | 2000 Yamaha WR 400 F
I have a liquid cooled 4 stroke scooter. It runs
Check the cooling liquid qty. I feel engine piston is seizing. Replace the engine coolant as per the manufacture's recommendation.
Mar 29, 2010 | Yamaha YZ 250 F Motorcycles
Boating Logo
140 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
