Question about Tacsew T500
Timing procedure - Tacsew T500
    President:
  • 2,047 Answers
What happens to be the problem with the timing procedure? Please give more concise details to enable me profer a reasonable solution.
Hoping to hear back from you.
Posted on Mar 14, 2011
Anywhere i can download a repair manual showing hook to needle procedure settings on the above machine
Repair are difficult to find as usually only service repair personnel had access to them.
However, you can search the internet for web sites and videos with instructions on needle/hook timing adjustment.
sewing machine timing Google Search
Jan 27, 2016 | Sewing Machines
My consew 226R-1
Hello lilliang ,
You can check out the procedure in ur manual itself in detail!!
Mar 26, 2008 | Consew 226R-1
How can I set shuttle timing?
go google and type in ---singer sewing machine needle and hook timing procedure
yes it is a singer but the principle is the same for all makes of machines and the detail is good
If you like change the search from singer to brother and include the model number
Jan 23, 2016 | Brother CS-8060 Computerized Sewing...
I keep breaking needles on my Brother 1034D.
Sounds like your timing has messed up ... your booklet should tell you how to adjust this. If you do not have the book, Google "Setting the timing on my Brother 1034D" and you should be able to figure it out using a video or someones procedure ... good luck!
Nov 30, 2013 | Brother 1034D Mechanical Sewing Machine
I think a thread got stuck in the bobbin area....and now the needle won't pick up the bottom thread.......
Make sure you clean all the broken thread out of the bobbin area first. It sounds like you knocked the timing out when the thread knotted up. Look in your machines manual on the procedure to re-engage the timing. It will probably be a push this button in while turning the hand wheel until you feel the clutch re-engage, type of procedure.
Good Luck!
Chris
glfi.com
Feb 11, 2011 | Necchi 4575 Mechanical Sewing Machine
It sounds like in bobbin is not hitting the needle the right way it will so good 15 to 20 inutes then it will skip stitches i was told the timming was not right
The bobbin should not be hit by the needle (sorry but your question is confusing).
If the timing is not right, it will not sew properly. Take it in to be timed; the machine sounds like it is in need of a service procedure anyway. It will come back running like new.
May 05, 2010 | Juki TL-98Q
How do I time my Pfaff 1222E. The niddle hits the bobbin holder rather than the hole in the bobbin holder
I could write up the procedure but it would be too much for me to type in. Or you can purchase the 1222E Repair Manual and download it. It's pretty easy to work on as long as you have similar tools to clearances.
Apr 07, 2010 | PfaFF Creative 7570
My wife has a singer 5808c sewing machine. The thread is buching up at the bottom. Can anyone tell me the timing procedure for this machine as I believe it is probably out of time-thanks in advance
Hi it's probably not threaded correctly or needs oiling. If you can find out where the oil goes then tell me as my machine is experiencing the same problem and it's fresh out of the box!
Oct 18, 2009 | Singer Sewing Machines
Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Apr 25, 2008 | Elna 2007 Mechanical Sewing Machine
Tacsew T500 Logo
96 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
Shehu Pro
Shehu Pro
Nick Olsen
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
