Question about ProSound Audio Players & Recorders
Prosound 'USB Vocal Dynamic Microphone A98JB' plugged it into my laptop but its not working what can i do next to get it working
  • David Alcock Sep 15, 2012
    My prosound USB mic is asking for drivers. It knows the Identity and manufacturer of the prosound mic, but my xp does NOT have the drivers to operate it so it does not show up in audio properties either.
  • 3,400 Answers
Go into your preferences and make sure input is set to external mic
Posted on Mar 14, 2011
What type of pickup is in the mike
EC2/58, which includes the world-famous Shure SM58 cardioid
dynamic microphone.
• EC2/87, which includes Shure's SM87 supercardioid condenser
microphone.
• EC2/Beta 58, which features Shure's premium supercardioid dynamic
Beta 58 vocal microphone.
• EC2/Beta 87, which features Shure's premium supercardioid
condenser Beta 87 vocal microphone.
You can look you do a search. Just put in the mic model in the search bar.
You can Y
Jun 11, 2014 | Shure Audio Players & Recorders
I can't seem to figure out how to connect a vocal microphone or were to plug it in in the onkyo tx- sr804 please help!!
for modern receiver, it normally does not allow vocal microphone input. vocal microphone requires an amplification stage which are not normally there. to do this, you'll either need to buy a very cheap mic preamp or a karaoke machine to do this
Oct 27, 2013 | Audio Players & Recorders
Can microphone be used with computer?
Yes, if it's similar to what is pictured above and your computer has a microphone input on it. As long as the computer has the input the most you would need to do is get an adapter for the microphone to get the plug to the correct size. Often times microphones have a 1/4" jack which looks like a larger version of what your standard ipod headphones has. The plug would need 1/8" to work on a standard computer. 1/8" is the size of the standard headphones. Adapters can be purchase from RadioShack for couple dollars.
Hope this was helpful
Ray
Mar 02, 2011 | Samson Dynamic Vocal Microphone
Just purchased Samson dynamic microphone. Can we use this with a portable stereo or computer? If yes, how does it work? What do we do to set it up?
You can use it with a portable stereo that has a microphone input socket - just plug it in. You may need to adjust a mic volume control - this will vary from one system to another.
With a computer just plug it onto the microphone input socket (usually colour coded red or pink)
You will also need to enable it in 'control panel' - see below.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 14, 2011 | Samson Dynamic Vocal Microphone
Plugged in found drivers still no sound dynamic microphone a98jb
Try uninstalling the program to clear the computer, then re-install the drivers on to your computer. Your computer may not be compatible with the microphone program, you may not have enough spce on you hard drive to get the correct download.
Oct 19, 2010 | ProSound Audio Players & Recorders
How do u get hsm wii microphone to work on
well ..i cant see what type of conection you mic has and what you really want to achieve as far as quality of sound or ultimate use..,but...here are some ideas.. A mic needs a pre amp and that is often built into some cheap but usable mini mixers made by behringer..You could pick up one and a good cheap dynamic mic[dynamic mics are best close to the sound source] with a lead and then go from the main output of the little mixer to the audio input of the computer.. A second but easier way and one that could give very good results is purchase a USB input microphone and this will have mic pre amp built in so it just plugs into your computer usb port.. SE electronics ,Rode make brilliant ones that are used often for podcasting..[well worth the +-100 uk pounds] but i am confident that berhinger will make a usable model for much less money[these type usb condensers will be sensitive and give clear results]...
Mar 21, 2010 | Logitech Vantage USB Microphone for...
Im gettin only one side when i record a vocal wit mixcraft 3
Make sure your recording onto a Mono track in your software, don't choose stereo when creating the track.
Feb 20, 2010 | Samson C01U USB Condenser Microphone...
HOw do you plug the Samson M15 into a stereo? Or
You need a small mixer to boos the level of the mic to line level.
We here at Pro Line Music have small mixers that can do this.
215-736-8055
Dec 25, 2009 | Samson Dynamic Vocal Microphone
What hp laptop sound card would be good for decent recording vocal/instruments
what u need is agood quality microphone buy ahuja microphone then do the recording of the vocal for studio quality
Sep 05, 2009 | HP Computers & Internet
NT3 or NT1A?
Either mic will work for piano, vocal and guitar.
Jan 02, 2009 | Rode NT3 Professional Microphone
991 people viewed this question
Top ProSound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ProSound Audio Player and Recorder Expert? Answer questions, earn points and help others
