Computers & Internet Logo
Anonymous Posted on Apr 07, 2017
I have windows 7 with avg antivirus full version installed. i am not able to install the latest version of yahoo messenger. when installing, getting error message: "yahoo messenger! is unable to download files for this installation. please check the firewall settings and then try again." i have disabled avg firewall - no go, uninstalled avg completely - no go, the windows firewall was already disabled in the system so tried enabling it and try - no go... i know some sort of esception has to be added to the firewall.. since it did not work even after uninstalling avg, then the problem is with the windows firewall.... so any idea?
lorrie
Level 3:
Master:
  • Master 37 Answers
  • Posted on Apr 07, 2017
lorrie
Master
Level 3:
Master:
Answers
37
Questions
0
Helped
5054
Points
3000
To Fix (Yahoo Messenger Download Error Firewall) error you need to follow the steps below: Step 1: Download (Yahoo Messenger Download Error Firewall) Repair Tool Step 2: Click the "Scan" button Step 3: Click 'Fix All' and you're done!
  • lorrie Apr 08, 2017
    Use the newest version of Yahoo Messenger. Updating can also fix issues from using older versions of Yahoo Messenger.
5 Related Answers
Anonymous
  • 3422 Answers
  • Posted on Jun 16, 2008
SOURCE: security
Lets fix this problem with a remote assistance?By the way if you cant see the icon on your desktop go into the program folder of your c-drive and open the folder of your antivirus.
Anonymous
  • 116 Answers
  • Posted on Feb 04, 2009
SOURCE: Here's the full error report:
make sure you have removed all other antivirus software before installing AVG (or any other antivirus software)
try to uninstall AVG, then restart and install it again
Anonymous
  • Posted on Feb 07, 2009
SOURCE: unable to install yahoo messenger
i did solve the problem by downloading a lower version
Anonymous
  • 52 Answers
  • Posted on Feb 14, 2009
SOURCE: Action failed for file avgtdix.sys: starting service....
There is a known issue between AVG 8 and Anniversary Edition of Ad-Aware which gives exactly this error, so if you perhaps just got that ad-aware, uninstall it too before trying to reinstall AVG.
Then run the uninstall/cleanup util for Avast because the Windows Add/Remove isn't good for uninstalling antivirus programs. Then try reinstalling it again. If you downloaded the installation package, then it provides the uninstall option. Disable Ad-Aware's Adwatch first! Run the AVG installer. Choose the uninstall option and follow the wizard. When you get to the part to remove user settings, select it. Restart your computer then... Now reinstall AVG using the setup file you got and update it.
Restart Windows twice before you re-enable anything disabled earlier.
Should this not work and you get the same error, that means the original errornous installation is still not out of your system. Download the AVG remover from here:
http://www.avg.com/download-tools
Remove your AVG and reboot to make sure it is not there any more, and try installing again.
Let me know if the solution worked and if yes please rate me:)
Anonymous
  • 241 Answers
  • Posted on Jun 07, 2009
SOURCE: i've already downloading the latest yahoo
Try what it says, "check firewall settings and retry". Disable your Firewall software and try to download messenger again. It should work.
When downloading yahoo messenger, why do I get an error that says Yahoo did not finish installing because there is a missing component?it says d3d9.dll was not found
Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
8helpful
11answers
My yahoo messenger have problem : 1. I can see what I type before I send but after I send it I can't see what I typed . 2. Whenever people send IM to me it showed his/her IM in a very small pop...
Welcome to FixYa!
The XML application in your computer might be corrupted which Yahoo Messenger uses to display the chat box properly. In most cases, it is the result of a virus/malware activity.
Here's what to do:
  • 1. Download the Free Edition of Malware Bytes HERE.
  • 2. Save the file.
  • 3. Double click the downloaded file or if prompted to run the file, click yes to install Malware Bytes.
  • 4. After installation. Launch or Open Malware Bytes. (Double click on the Malware Bytes icon on the desktop).
  • 5.Click on the Update Tab and click on Check Updates (It will download the latest virus definitions)
  • 6. After updating, click the Scanner Tab and do a Full Scan.
  • 7. After scanning, click on View Results.
  • 8. Then click on Remove Selected.
Note:
The Free Edition of Malware Bytes will not conflict your recent anti-virus software because it does not have real time protection features.
Try logging in to your Yahoo Messenger again.
If this does not resolve the issue, re-install Yahoo Messenger. Since the Malwares have been removed, there is a great chance that the re-installation will solve the problem.
I hope that this will help.
Thank you for using FixYa.
Jas247
Ym stops as soon as I dial the number. Message says : ym has stopped working and will close. 8.1.0.421, windows 7
you are using old version of yahoo messenger..
you need to uninstall the version from add and remove program and install latest version 10
you can download the latest version from http://messenger.yahoo.com
2answers
I try to open yahoo messenger but this comes out "yahoo messenger.exe failed to initialize."
1. Uninstall your Yahoo Messenger
2. After uninstall completed go to My Computer - Program Files and delete Yahoo folder.
3. Install again Yahoo Messenger from www.yahoo.com
4. Install latest adobe Flash player from www.adobe.com
5. Install latest JRE version from http://java.sun.com/javase/downloads/index.jsp
6. In a command prompt window type command: del %temp%\*.* /f /s /q
7. Restart your computer.
After all of this if your problem continues check for operating system errors.
9helpful
3answers
Unable to Install Yahoo! Messenger Firewall Issue or What?
The problem is with the Yahoo uninstall software which fails to clear the old Messenger folder out and creates conflicts with the incoming new software - Your firewall doesn't know whats happening and hoists a red flag. If you had not started to uninstall I would have recommend you download revo and uninstall with that.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
bear this in mind if you manage to install messenger but still have problems
You have to go into your C drive and delete the left behind software
Click ( > ) Start > Computer >> Local disk (C) >> Program files >>Yahoo >> Messenger - if you have Vista the folder should be empty - if you have pre- Vista the only sub-folder remaining should be 'Profile' ( The message Archive file) manually delete everything except 'Profile' by right clicking and deleting. When finished restart your computer and finish the install
3helpful
Yhaoo messenger problem
Your Yahoo messenger is currupt, might be bcoz of virus infection.
  • Please uninstall yahoo messenger,
  • use any good antivirus to remove virus
  • remove yahoo messenger registry entry using System Mechanics or cCleaner
  • Repair windows using WINDOC or from system installation disk
  • Now download and install latest version of yahoo messenger from www.messenger.yahoo.com
Hope it will work
Thanks
Zulfikar
9helpful
2answers
Installation of yahoo messenger won't install
Yeah it been a problem for so many others like you, check out this official solution at YMessBlog
But I recommend to you install a standalone version ;
A standalone version is a full complete installation of Yahoo Messenger ,which doesnt connect to internet for further installation of the software.
So download the latest Yahoo Messenger from here at softpedia
Hope that helps !!
I HAVE A STRONG VIRUS IN MY COMPUTER
Your antivirus may be corrupted by the virus, or it has not this virus on the latest update
First install an antivirus, update it to latest version , and try doing a full scan: AVG Free - Download AVG
If the antivirus is not enough use an antimalaware that removes more viruses use this one: Spybot - Search & Destroy - Free software download , install, update, and perform a full system scan.
If that is still not enough, the best thing to do is doing a backup of your files, and reinstalling Windows.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
