Question about Whirlpool Duet GHW9150P Front Load Washer
My whites have a grey color after washing. Is there a procedure to clean the washer like cleaning a coffee pot with vinegar?
  • 604 Answers
The problem is your water supply most likely. have you tried using a commercial water softening product? or maybe bleach.
Posted on Mar 14, 2011
Coffee has a tangy flavor
You need to clean the coffee maker.Use white vinegar.Just fill the reservoir with and hit brew.When it is done.Fill the pot half way with ice and one hand full if salt.Swirl the pot till all stains are gone.Then run one full pot of clean water,to rinse.Make yourself a fresh pot and enjoy.
May 16, 2011 | Keurig B60 Coffee Maker
Accidently left coffee pod in coffee pot while went on vacation now the machine smells really bad . tryed vinegar but nothing seems to help
Try the rinsing procedure that's in the manual, and use citric acid. The parts that usually come into contact with hot water or coffe can also be cleaned in a dish washer.
Sep 01, 2010 | Philips Senseo HD-7810 Coffee Maker
How to clean
mcdevito75 here, Start with a new paper filter or claen the perminant one, you"ll need enough WHITE VINEGAT to fill the pot itself 3/4 full of this WHITE VINEGAR, NOW pour the pot of 3/4 full of WHITE VINEGAR into the resovoir, replace pot in the coffeee maker and cycle thru the vinegar 3 times, each time letting the mavhine cool a bit for easy handleing, on the 3 rd cycle stop 1/2 thru the brew cycle, let machine cool for 30 Minutes, then complete that cycle. Now repeat with fresh water to reove all the vinegar from the machine. Your coffee maker should now be good as new.
Jun 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
I have a Mr. Coffee model JHX33 coffee maker, and have lost the owners manual I need cleaning instructions. Can you possibly help me?\r\n Thanks Eddie Thatcher
mcdevito75 here, I too have a Mr. Coffee, coffee maker 4 cup. The instuctions shold be just about the same for both our Mr. Coffee mavhines, ------ With a new or clean filter in the machine fill the pot 3/4 way full of White Vinegaar the pour that into the resovior, place thepot back in place on the machine and start the machine up, let the vinegar cycle thru, when done the vinegar is now in the pot, empty the pot back into the resovoir, and cycle again, this time 1/2 way thru the cycle or pot half full stop the cycle for 30 mins. this will keep the vinegar in the machine and claen all the little ports. After 30 mins, complete the cycle. repaet this 2 more times. Then repaet once the machine is cool but this time use plain water, repaeat plain water cycle 3--4 times to clean out all the vinegar, Mr. Coofee needs claening when you notice coffee brewing has slowed down or maCHINE STEAMS TOO MUCH DURING BREWING CYCLE.
Jun 19, 2010 | Juicers
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker works very slowly after about three weeks of use. Specifically, the water does not pass through the filter and into the pot quickly, if at all. Suggestions?
Try cleaning it with white vinegar. Put in one cup with a potful of water, and let it soak. To get more cleaning, pour the water/vinegar through again, hot. Put in a coffee filter to catch/strain the debris, and you will be able to see if it's helping. When you're through cleaning, pass fresh water through the machine by potfuls, until no traces of vinegar can be detected.
Best regards, --W/D--
Aug 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Bad taste in coffee
Run a pot of 1/2 white vinegar and 1/2 water through a cycle. Then run 2 cycles of plain water. Wash pot and basket in the dishwasher.
Jun 12, 2009 | Breville Die Cast 800ESXL Espresso Machine
Need to find manual for bunn coffee maker
You can go to Bunn.com and print one out or I think buy one. To clean you need a deliming spring and white vinegar. You put the spring up into the hole where your water comes out of to empty into your carafe. Remove the grounds basket. then remove the spray head by twisting off. Then you are ready to put the spring into the hole. Insert all but a couple of inches into it. If it has been awhile you may have to force it by twisting and pushing. Work the spring up and down and it will eventually go in and out with no problem. Check the holes in the spray head to make sure they are clean and free of any build up. As you know Bunn has a reservoir where water is kept hot. You put in and what is in the reservoir comes out. Pour 1 quart of white vinegar into the pot. Let it sit for two or three hours or longer is OK. After your wait pour water in 8 to 10 times to flush all vinegar or you can unplug the pot and turn upside down over the sink. If you do this while the water is still hot be careful. Most of the water will come out of the hole where you put the deliming spring into. Some will come out of the top possibly. If you do it this way make sure you fill back with water before you turn it back on. Repeat vinegar flushes again if you water isin't running clear yet.
Mar 14, 2009 | Bunn NHB Coffee Maker
How can we clean our saeco pot.
White vinegar will work well. After you run the vinegar through, run about 2 pot of water through it to rinse. This should do the trick.
Dec 24, 2008 | Saeco Odea Giro Plus Coffee Maker
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
