Question about LG DLE7177 Dryer
Power button on my lg dle7177wm dryer broke (pushed in and would not come back out) and now will not work at all. Before I tear it apart and break plastic tabs, can you advise me as to how to get front panel off and whether it is just one switch or possibly the whole board that I will have to replace. Thanks!
  • 604 Answers
Try spraying some lubricant into and around the button, keep pushing lightly, usually after 10 or so tries the button will pop back out.
Posted on Mar 14, 2011
  • Hayley LJ
    Hayley LJ Oct 30, 2013
    Same thing just happened to my dryer. Thankfully, I followed Mr. Brown's instructions before calling a repairman. It worked!!
Where is the reset button?
There is no reset button, the issue is most likely a heating element
Feb 02, 2015 | LG DLE7177WM 7.3 Cu. Ft. Electric Dryer -...
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
HP deskjet 3054 broken power button
Hp's usually have a micro switch underneath the power button. You probably just broke a support arm or type device. You might be able to super glue the piece back together and make it work. In my experience, this usually works about 40 percent of the time. Usually by pushing to ******* the switch to break the plastic you could have possibly damaged the small micro switch. My best suggestion is take it apart and try the super glue fix first. Good Luck!!
Jun 13, 2012 | HP Deskjet F2210 InkJet Printer
DLE7177WM - Seems to work ok, but it is taking
Its going to be an issue with the wall vent of your house. The dryer is not venting the air at a good enough volume and that is why it is taking longer to dry. Sometime you may have to run a second cycle and I bet there is lint on your door gasket around the 6 o'clock positon.
The flex vent behind the dryer, the wall vent, and or the vent's outlet (roof or wall) outside the home needs to be cleaned to improve the air flow.
Good Luck.
Jul 04, 2010 | LG Dryers
LG DLE5977W dryer - thumping
its not the belt its the rollers you can get a kit that the belt the tensioner pulley and the rollers all come together if your replacing the rollers seeing how you already have everything apart u might as well just install the kit if your belt were broke youd have no spin you can order these from marcone or allbrands appliance they willmail the parts directly to you hope this helps
May 01, 2010 | LG DLE5977 Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
I have the LG DLE5977S dryer. When I push the
The belt could be broke or the idler spring may have come of in either case you will have to take the machine apart to find out which.
Mar 21, 2010 | LG DLE5977 Electric Dryer
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
I have an lg dle7177wm dryer - i'm trying to get to the heating element to check for a circuit and am having trouble figuring out how to get the dryer apart
Try this approach.. with the dryer situated so that you can access the back of it.. look at where the top cover projects over the back..directly beneath that is 3 screws that when removed ,..should allow you to slide the top back and release it from the chassis.. Once that has been done, you should be able to remove the front panel ( after you undo the lint trap screws with the door open ).. You can tilt the front panel away from the cabinet to unhook the door switch.. than you should be able to lift the front panel assembly up and off the guides on the bottom.. Once it is set aside, you should have access to everything you need from the front.. Hope that helps...
Aug 16, 2008 | Dryers
LG DLE7177 Dryer Logo
318 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
