Question about Bosch Refrigerators
Whatever temp I put the thermostat on the fridge is freezing the food and ruining it - any suggestions?
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Mar 14, 2011
My Lg fridge Model # LFX25980ST is freezing my food in the lower portion of the fridge
Lower the number on the temp dial or replace the thermostat.
Jan 03, 2017 | LG Refrigerators
Side by side fresh food side freezes
Good question. If you have access to a thermometer I would put it into a glass of water and stick it in the fridge. Give it a day and you will now your product temp
Sep 06, 2012 | GE Refrigerators
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
My fridge is freezing food
HI,IF YOU REFRIGETOR IS FREEZING FOOD CHECK YOUR TEMP CONTROL OR THERMOSTAT AND THE AUTODAMPER (airflow control) PROPERLY CONDITION,,IF THE TEMP CONTROL IS BAD THE COMPRESSOR WILL BE WORKING ALL THE TIME,IF THE AUTODAMPER IS BAD WILL BE COOLING TOO MUCH..
Feb 21, 2011 | Refrigerators
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Fridge is freezing
There are two things you need to make sure before you declare the fridge at fault. Firstly, make sure that fridge isn't overloaded with items and that any air vents aren't blocked. Give it room to circulate the inside air. That helps it to cool evenly/at all. Next, find the thermostat. This will most likely be inside the top of the door frame when you open the door on newer fridges, or somewhere along the back or side walls. There'll be a setting for the freezer, and a setting for the fridge. The knob might use letters, numbers, or an arrow that says COLDER. Set the knob to slightly warmer, then leave the fridge alone for 24 hours. I highly suggest putting a suitable-type thermometer in the fridge and adjust the temp until it's around 34-38 degrees F. Do NOT allow the fridge to become warmer than 40 degrees. Between 40 and 140 degrees F is the "danger zone" where microbes thrive in food and are much more likely to cause food poisoning. You must never let food sit in the danger zone for more than 4 hours.
If cleaning the fridge and adjusting the thermostat don't work, you'll definitely want to have a refrigeration professional take a look at the fridge. It may as simple as adding coolant or "freon".
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Frozen food in fridge w/ no temp change
yep there is,,, its called the thermostat its just packed up on you,,it will do one of two things now,,, freez every thing solid or defrost every thing,,,,only one thing you can do to put it right, fit a new thermostat
Nov 10, 2009 | Cars & Trucks
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
324 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
