Question about Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive
My 32g flash drive keeps giving me a "write protection" error. There is no switch to change this please help.
  • Transcend Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps don
Posted on Mar 14, 2011
Hedd datatraveler 32g write protected
Try this link
http://www.tomshardware.com/forum/284827-45-remove-write-protection-flash-drive
Apr 14, 2013 | Computers & Internet
Tip
USB Flash Drive | Write Protected
Hello and Welcome to FixYa! <br /> I have noticed similar queries that My USB flash drive is not formatting and showing the error that "The drive is Write protected" or something similar, although there is no protection latch or switch, So what to do. <br /> There may be two issue one with the fat structure of the drive other with the components, if the hardware is damaged then there is no luck, but if the fat is damaged and windows is unable to format it, you can repair it with a nice and small tool. <br /> Just download, extract and run <a href="http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip">this application</a> to Repair your USB Flash drive. <br /> Have resolved the Write protection issue on many drives with this, do share your experience as well. <br /> <br /> <b><i>Thank you for using FixYa!, Keep visiting..</i></b> <b><i><br /></i></b> <b><i>If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.</i></b> <b><i><br /></i></b> <b><i>Concerned, Nooh</i></b>
on Jan 23, 2011 | Computers & Internet
I can't format my usb flash drive. when i plug-in my usb, the computer said, "you need to format the disk in drive F" then i click, "ok" then i click "start formatting"...
lots of flash drives have a little switch on the drive which will say something like lock-unlock or protect--open this needs to be set to the open position,also right click then properties the drive in my computer and it could be set as protected there so unprotect and carry on.hope that helps.
Jul 10, 2011 | Computers & Internet
This is changing my folders into shortcuts on my usb flash drive and it gives me an error message saying "Windows cannot find 'G:\RECYCLER\0xFFD12566.exe'." please help.... it's very...
Those things are happen when a computer is infected with "Malwarewares" through' external drive eg. flash drives or downloading & installing programs/software from "unknown websites", etc... due to inadequate protections/preventions on your PC/Laptop.
Here a help link to remove the "unwanted files type" in your Operating System" @ http://www.bleepingcomputer.com/forums/topic206037.html/page__hl__RECYCLER
You can use both effective free malware & Spyware programs, like Malwarebytes Anti-Malware & SUPERAntiSpyware,download install & update the database to the latest and scan your PC & any external USB drives.
Use a Free System utility tool eg. CCleaner to cleanup any "craps" from your PC too.
Your will have quite tedious tasks ahead cleanning out the "unwanted malware files
Jul 01, 2011 | Computers & Internet
My flash drive keeps saying it is write protected.
Three possible Solution to this problem are:-
1:) First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
2:)Use a software tool Neo2.9
3:)1. Open Registry Editor by typing regedit in Run dialog.
2. Navigate to the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
3. Find a sub key inside it named "StorageDevicePolicies". If it does not exist there then we need to make it. Right click on "Control" key -> New -> Key. Name it "StorageDevicePolicies" without quotes.
4. Now right click on this newly created key and then click New -> DWORD value and name it as "WriteProtect".
5. Modify this key and give it a value 0.
6. Click OK, and remember to restart the PC.
GOOD LUCK...........
Feb 06, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB IS WRITE PROTECTED HOW DO I REMOVE THE WRITE PROTECTION SO I CAN USE THE FLASH DRIVE
It depend on the flash drive.
First, the easier, check if there is a tiny switch in your flash drive. You can easily change the switch position.
Second, if no switch, it means you have "error" problem with the drive. You can download the software in the producer's website, or you can contact the producer and they might give you the link to download it.
Third, if no software offered by the producer, then you have quite big problem. Many have this problem if they unplug the driver unsafely. One possibility to remove the write protection is going to the "Regedit" and change the value of :
go to ‘WriteProtect’ and change the ‘Value Data’ to ‘0’
Jan 13, 2008 | iLO (2 GB) MP3 Player
Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive Logo
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
