Question about Dryers
My zenussi td62 dryer is not heating up to dry my clothes ? it spins but dosnot warm up, do i need to buy a thermostste ? and are they easy to fit ? please help i cannot afford to buy a new one.and are there any diagrams thanks Paul
  • 827 Answers
Is this electric or gas dryer??? big difference in how to proceed. the cost of a replacement part and time, etc. still may be high compared to the alternative of checking out your local habitat for humanity "restore" (find locations online) they have gently used washers, dryers (50-75 bucks) and so much more at all at a fraction of the cost... you can't get a service man out for the prices they charge... typically they warrant that the unit works or bring it back for replacement.
Best regards
Ck
Posted on Mar 14, 2011
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Frigidaire dryer displaying code E4A, clothes are not drying
Hello - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire Dryers
Electric dryer heats up and blows air but doesnt dry my clothes
I would check to see that the lint/filter isn't completely clogged up. This could make the dryer warm without allowing it to do its job of drying the clothes.
Also, is the drum spinning? If not, it could be indicative of other problems.
Nov 13, 2012 | Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Dryer heats up but clothes won't dry
Check that the lint filter is not blocked or that the oulet hose is not kinked
Feb 04, 2010 | Dryers
Wdl540 clothes go through drying cycle but come
If there is no heat at all then the heater or the temp sensor or the thermal fuses are defective and need replacing.
Also check that the lint filter is clear of debris and lint. Rinse it if necessary in some mild washing up liquid in warm water and dry thoroughly. Check that the air outlet hose is clear if you have one fitted. Check that the condenser is empty of water and the case is free from dust and lint. Vacuum / brush or wash the outside of the collector in washing up liquid and warm water and dry.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
No heat, will turn on and spin with cool air only. does not dry clothes.
Okay, let me try to solve this with three possible solutions:
EASY AND CHEAP: Check the hose, the lint filter and the vent for obstructions. If the air is not getting out then the safety switch in the dryer will tell the element not to heat up. Without this safety switch the dryer becomes a fire hazard (and that's a whole other FixYa problem!). Make sure the hose is not crimped or clogged and that the outside vent is opening properly.
HARDER AND MORE EXPENSIVE: The heating element may be burned out or have a loose connection. This is a little bit harder fix but can be done without consulting a repairperson. However, if you have little or no experience then don't try that at home.
EASY BUT MOST EXPENSIVE: Buy a new dryer. If you do, see if the company you buy it from will take a trade in. If not, call a small appliance repair shop and see if they would like to buy your machine to repair and resell. This might offset some of the cost of the new dryer.
Hope this helps. Good luck.
May 26, 2009 | Kenmore Dryers
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
The dryer heats up & spins,clothes don't dry,lint areas are now clean
restriction in your vent check it from the back of the dryer it must be 4 inches in dia and clear get a flashlight and look behind the dryer see if its mashed coiled or folded check the dryer hood make sure if there is a bird screen on it its clear easy way to tell if vent is at fault disconnect from dryer and do a load then let me know
Jun 05, 2008 | Roper REX5635E Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
