Question about Brother HL 5250DN Laser Printer
Paper becomes wrinkled as it passes through rollers especially when printing duplex.
2 Suggested Answers
  • 1575 Answers
SOURCE: Paper jam. Sheet printed but didn't pass
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Posted on Oct 31, 2011
HP 4215xi all in one, continues to give the error paper jam, there is no paper jam. I have cleaned all sensors, rollers etc. I have tried a partial and full reset. Any ideas?
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 2: Removing the rear access door
Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  1. From the rear access door opening, remove the jammed paper.
  2. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  3. Reinstall the rear access door.
  4. Reconnect the power cord to the unit and turn the unit on.
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Goodluck..
Mar 17, 2008 | Computers & Internet
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
How can I stop paper jams when using duplex printing?
1. Replace "Roller top out put bin" (RL1-0527-000CN)
2. Clean duplexer unit & chk the rollers in size change assembly(RM1-1318-000CN)
Apr 29, 2014 | HP LaserJet 1320tn Printer
Multiple sheets of paper feed from rear tray causing jamming and prevents duplex printing. Printer has been cleaned, including rollers
your seperation tires are not working check that they are clean and are turning and that the paper is laying flat and not wrinkled or bent over.
Jan 27, 2011 | Canon MP610 Photo All-In-One Printer
Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Xerox Tektronix Phaser 7700 Laser - Wrinkling paper slightly.
Hy the problem is: You have to clean the 2nd BTR and the transfer belt cleaner. There is a large amount of used toner on those things.
Oct 30, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Brother HL 5250DN Laser Printer Logo
326 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
