I have Sanyo lcd model32xa2.the panel resolution is1366&768.There isno hdmi input inthe tv how do l get Hd. Signal. If I connect Hd dvd player or Hd receiver.Please answar
  • saibaganguli Mar 28, 2011
    Thai is helpful.What do you think about this MODEL SHALL I CHANGE IT OR KEEP IT. THIS IS MORE THAN FOUR YEARS OLD BUT PICTURE QUALITY IS
    EXCELLENT.PLEASE ADVICE ME.REGARDS SAIBAL
  • 325 Answers
Component inputs (blue, etc) are rated upto 720p, OR look for a DVI input (thin and white)
These will be your only two options with a no HDMI inputs!
Please rate if this helped :)
Posted on Mar 14, 2011
  • 1 more comment
  • Andrew P.
    Andrew P. Mar 28, 2011
    This will be your personal preference! I know people who won't get a flat screen tv and stay with projectors. If you enjoy your picture, keep your tv!
    Thank you!
  • gangulimithu Apr 11, 2011
    Thanks FOR YOUR ADVICE.I AM GETING MUCH BETTER PICTURE THROUGH COMPONENT VIDEO.BUT I WOULD LIKE TO KNOW IS IT REALLY ATRUE DIGITAL HD QUALITY PICTURE OR JUST UPGRADED ANALOG PICTURE THROUGH COMPOBENT VIDEO.REGARDS SAIBA GANGULI
  • Andrew P.
    Andrew P. Apr 11, 2011
    You can get TRUE HD from projections (it's just resolution values). Component is true digital source, but you will need a new tv to see the higher 1080 resoultions through HDMI or DVI
THANKS,I VOUGHT ONE COMPONENT VIDEO CABLE AND IT IS WRITTEN. THERE THAT IT CAN UPSCALE UP TO 1080!IS IT TRUE? REGARDS SAIBAL GANGULI
Posted on Apr 11, 2011
    Thanks.IN MY COMPONENT VIDEO CABLE IT IS WRITTEN THAT IT CAN UPSCALE UP TO 1080!.IS IT REALLY OR AGIMI
    B
Struggling to connect my Goodmans Freeview+ HD recorder (HDMI output) to either the DVI (female) or VGA (female) input of my Samsung LE27T61B TV which is HD ready with a resolution of 1366 x 768.
They are different protocols. You have to have a converter than changes the protocol (protocol is like a language...it needs to be translated to a different language). They are available from eBay or amazon but they don't always work very well. Best thing to do is get a unit with the correct connections.
Jul 14, 2016 | Samsung Televison & Video
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Televison & Video
Why is tv saying no signal?
Connect a known working DVD player by using a new HDMI cable to HDMI INPUT 1 and check for signal.
If you have a DISH or CABLE system box, connect that also with a new HDMI cable to HDMI input 2 or 3 and recheck for signal. Your T V remote will have an input selector to change between the different inputs on your
T V.
Sep 08, 2014 | Proview HX303 30 in. HD-Ready LCD...
Why rgb connection o.k. NO TV signal?
Check your manual for instructions to select video source. Also , please be aware that rgb video also usually requires separate audio connections along with the rgb.
Jun 08, 2014 | LG 32LK310 LCD HDTV, 32 Display Size, 16:9...
I connected my dvd player to my coby hd tv, and the movie still want play, maybe I have it on the wrong chanel. What chanel should the hd tv be on?
Are you using a HDMI cable? Push the SOURCE button & select the corresponding HDMI input with the HDMI input from your DVD player. The HDMI inputs on the tv should be numbered & you can then select the correct number HDMI on the source screen. Good luck.
Sep 02, 2013 | CobyElectronics Coby Electronics Coby...
I have one SANYO LCD MODELNO32 XA2.THIS SET DOES NOT HAVE HDMI INPUT ONLY SCART,COMPONENT AND COMPOSITE VIDEO IT HAS.THE PANEL RESOLUTION IS1366 768 IF I CONNECT ANY HD BOX ORBLUE RAY PLAYER THROUGH...
Hello, yes you should have no problem with picture quality the difference should be hardly noticeable. You should however buy good quality leads to make up for the lack of HDMI ( High Definition Multimedia Interface). If the Blue Ray only has HDMI output, you can get an adaptor from Tandys or similar. I hope that helps you.
Mar 29, 2011 | Sanyo Televison & Video
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
Dec 09, 2010 | Video Game Consoles & Games
Does my Toshiba 37HLV66 LCD TV/DVD Combination have the capacity to properly accommodate a Blu-Ray player? Some technicians I have asked say, "yes" and others say "no."
This can be both yes and no. Looking at the specs of your TV it would not be displaying in full 1080p (The highest resolution for HD)
The best part of Blu-Ray is viewing this in 1080p. Your TV can accommodate a BD player and would be best set up using the HDMI input port on your TV. But, it will limited to your resolution of 720p or 1366 x 768 on your TV and most DVD players can upscale the quality of a movie to 720p or higher. It would be worth getting a TV that has 1080p to go with a Blu-Ray Player.
Nov 03, 2010 | Toshiba Televison & Video
Not able to get picture when connected to PC via HDMI
bbutler,
Your Toshiba can handle PC screen resolution up to 1024 x 768
Lower the resolution of the PC screen to somewhere between "640 x 480" and "1024 x 768". It will work just fine.
It's not likely that there is a any physical problem with either the PC or HDTV.
1. Right-click anywhere on your desktop
2. [Properties]
3. [Settings] tab
4. Slide the "Screen Resolution" pointer to the LEFT to adjust and click on [OK]
*DONE*
Oct 16, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
