Question about HP Pavilion a1730n PC Desktop
I have an HP Pavilion a1730n. For the past 5 times I turned it on, I received an error message Error: The System Fan Has Failed!Service PC to prevent damage to the system.PressF2 to Continue I ran HW Monitor, but do not know how to interpret the results. What should fan speeds and temperatures be? I Gene
  • 79 Answers
This is caused due to wire signals that are sent from the fan to the motherboard.
Open your system case and make sure the fan is running. If it is running then make sure the cable terminating on the motherboard is properly inserted. You can take it out and re-insert.
If issue persists, then you may have to change the whole fan or disable the warning option in BIOS which can be dangerous.
Posted on Mar 14, 2011
  • 54 Answers
The maximum temperature for most CPU's is usually around 65-75 degrees Celsius. I would also recommend to just replace the CPU heatsink and fan assembly just to be safe. You can buy this in PC parts retailers and it's not that difficult to install it yourself. This is an easy and cheap fix.
  • 827 Answers
Fan temperature and speed? Good question,. relevance is more towards the likelyhood that you've stored your pc on the floor and have dust/ debris which have gathered - a good cleaning of the fan may work, otherwise replacement is like 5 bucks... the can of spray air should be readily available at staples, unplug the power source and remove the cables, cover etc,. get into the unit and give it a good blast to see if that will suffice,. otherwise a cheap fan would do.
As far as the temperature of the processor which the fan cools - it goes to like 350 degrees as soon as it is powered up.. so it is best to be sure you have good airflow in and around the unit.
Best regards
Ck
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
I have an HP Pavilion a1730n. For the past 5 times I turned it on, I received an error message Error: The System Fan Has Failed!Service PC to prevent damage to the system.PressF2 to Continue I ran HW...
1. Check if fan is spinning. If not, replace with new one or check cables.
2. Check if there are no swapped fan connectors when reconnecting mb cables.
3. Check BIOS update on HP website. Choose your OS here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3339287&
4. Check for a BIOS setting for disabling the fan monitoring.
5. Install a monitoring app which reports fan speeds and temps. See http://www.cpuid.com/softwares/hwmonitor.html
6. Check if CPU fan works.
Mar 14, 2011 | Computers & Internet
At the login I received this error message "cannot
Ignore for time being if possible and logon a few times as is. Reboot a few times as is. If still a problem try cmd as admin and use "netsh" "reset winsock" cmds
Dec 27, 2010 | HP Pavilion Elite M9060N PC Desktop
My HP Pavilion 21020n has given me an error message stating my system fan failed, where can I find the system fan?
open up the chasis and on top of the cpu the fan is located
try to reseat the cables of the CPU fan located beside the fan and if it doesnot work get a new compatible fan and get it installed by a local tech
Mar 11, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
HP Pavilion dv4000 Laptop There is a error message coming on my screen it says "104-Unsupported wireless network device detected . System Halted . Remove device ad restart." .I was cleaning my Laptop as...
Try the connectors near the WiFi receiver. The message is relative with thw wireless section. Try remove it from the device manager and reinstall it.
Stelios.
Feb 23, 2010 | HP Pavilion dv5000t Notebook
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
CPU Fan Failed
Yes that is what you need to do. It's either due to your CPU board having issues or your fan is just old and needs to be replaced. You always need to have a fan running to cool off your CPU. Let me know if this helps and if you need anything else.
Apr 08, 2009 | Computers & Internet
Desktop PC system fan failed error
hello.. this means that the fan which cools your pc is not working, get a new fan for your mode and fit yourself if possible or go to computer technician.
do not keep it using as your pc may crash.
its very important to keep the cpu cool to keep computer working. hope this help.
Must rate me.....
Thanks
Mar 25, 2009 | HP Computers & Internet
Error message 0x0000007a
Google HP error message 0x0000007a and see what feeds back. I get the best answers that way
Jan 05, 2009 | HP Pavilion a6600f Desktop PC
HP Pavilion a1730n PC Desktop Logo
224 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
