Question about NEC VT695 LCD Projector
I have replaced the bulb in the NEC VT695 projector and the light still does not work. I have heard there is ome kind of reset thing that I need to do. Please help me.
  • 442 Answers
Press the help button on the remote for 10 seconds
Posted on Mar 15, 2011
  • CA Sysop Mar 15, 2013
    Thanks!! Had the same problem, replaced the Lamp, and the Lamp light was still red even with the new Lamp... Aiming the remote at the front of the projector and holding down the "HELP" button for a full 10 seconds fixed it.
Nec vt 695 status light blinking four times after replacing new bulb
one of the fans in the projector is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 05, 2014 | NEC VT695 LCD Projector
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Mar 29, 2013 | NEC VT695 LCD Projector
Having a problem getting past the red blinking status and orange blinking when trying to start up a NEC VT595 projector. This is after installing a new bulb.
I have had the same problem with my NEC VT695, however, while trying to repair it, I actually broke off two pieces, first the arm that is attached to the lamp cover that depresses the button, and then the actual button itself. Does anyone know any way to bypass this need to have the lamp cover seated 'properly'?
Jul 13, 2011 | NEC VT595 LCD Projector
I want to connect my iPad 2 to the NEC video projector VT695. do I need a VGA or an AV adaptor?
you need this ----------- Apple MC552ZM/A Video Cable Adapter HD-15 Video - Male Proprietary
Jun 17, 2011 | NEC VT695 LCD Projector
When power button is turned on it has a orange light and the lamp button is red. It is not the bulb because it worked in another projector of the same kind.
The bulb is not lighting.
Make sure the covers are going on correctly if I remember this one has an inner cover as well.
There is a little micro switch that needs to be operated by cover going on correctly.
also check the plugs / connectors are ok.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | NEC VT695 LCD Projector
The display projected is very faint. The lamp light is not blinking to indicate a problem. Is this an issue with the settings?
Check the bulb hours remaining through the menu. The bulb gets dimmer with age, so it could be close to life expectancy (2000 hrs regular, 3000 hrs Eco) and failing. The indicator light is based on hours only and will shut down the projector after (2100 or 3100 hours of bulb use), so it could still be the lamp failing or a power supply issue, especially if it's dim right from start up. Hope this helps.
Feb 08, 2011 | NEC VT695 LCD Projector
I just replaced the lamp. Is there a reset proceedure for the lamp light?
No reset other then resetting the hours in the projector's menu. This is for reference only and will not keep the projector from coming on. If the lamp will not light make sure the lamp cover is all the way on and nothing has broken off of it.
Sep 28, 2010 | NEC VT695 LCD Projector
Is there anyway that i can connect a nec vt695 to my tv
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Sep 19, 2010 | NEC VT695 LCD Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
New bulb will not power up
I pressed the Help button on the remote for 10 seconds and it powered up. Not in the manual that you can do this.
Jun 23, 2009 | NEC VT695 LCD Projector
NEC VT695 LCD Projector Logo
1,974 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
