Question about Maytag MMV5000 Microwave Oven
Maytag MMV5186aaq touch pad doesn't recognize touches on all pressure points. I can't even set the clock.
    Brigadier General:
  • 8,909 Answers
That looks like you are in need of a replacement key pad.
I can't advise where to get one from as I don't know which country you are in.
Posted on Mar 14, 2011
My MMV5165BAW displays *** with micro, AM/PM, help..etc under each x. Display flashes this msg. Touch pad will not work, but when it displays to set the clock, touch pad will work. After setting clock
There may be grease or moisture on the the control circuit board, especially in the are where the keypad strip plugs into the board.
Or there may be a pad stuck on th keypad.
See the owner's manual here in case that might help you.
Otherwise, the controller assembly may need repair, which is usually economical.
Jan 30, 2013 | Maytag MMV5165 Microwave Oven
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
Aug 31, 2010 | Microwave Ovens
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
How do you set the clock on a Smeg SMS23 microwave oven - I'm stumped!
Ive been looking for an owners guide for you. this page link is as close as I can find. you may have to look on the machine for further model numbers as the exact model you list is not there. I am on a dialup connection so I am only able to upload the link, this may be of some help nice nuker!
jm
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Jan 27, 2010 | Microwave Ovens
How to set the clock on my sharp carousel microwave
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Sep 25, 2009 | Sharp Microwave Ovens
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Maytag MMV5000 Microwave Oven Logo
66 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
