I have bought a used Roadstar CTV 1021 10" portable tv for my caravan and need to know the size of the jackplug for the 12v connection. Regards Colin Howarth
  • 303 Answers
SOURCE: need fuse for 12V adaptor
agc 3amp
You can buy a new ac adapter by clicking on the hyperlink:
buy replacement ac adapter power charger cord for POLAROID pdv-0823a pdv0823a
Posted on Mar 05, 2009
SOURCE: need remote for sylavania tv model srt 2113
I bought a "Universal Consolidator" today for my own SRT2113, and it works like a dream. It's the 15 dollar universal remote you always wanted. Its menu, channel searching, volume, and, yes, the infamous GAME MODE even works (use the input button)!
Posted on May 04, 2009
SOURCE: tune T.V. without remote
any luck mate? i'm having the same problem. just bout a universal remote to find i still can't get to any menu!
Posted on Jan 26, 2010
bronk50
  • 27725 Answers
SOURCE: Dear sirs, I have been using
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 17, 2010
SOURCE: I have an Innotec SB791-5
It needs the larger size. Also, the contact clip should be replaced with a spring-loaded type.
Posted on Jul 25, 2012
Want to buy earphones. What connection on the lead is needed to connect to system?
You may need to use an adapter to connect the mini stereo plug if the front panel PHONES connector is standard size.
Mar 16, 2015 | Pioneer Audio Players & Recorders
I can't get a picture on my Roadstar LCD8082D TV
The TV has two main sections One is the Audio component. And 2 is Video section. Since they are Separate and not dependent on one another with the exception of synchronization; (matching Voice to the Video), one section may work just fine. The other non-working section in your case is the Video. Over time various internal parts age and wear out from use or hot/cold. In the Video section a series of Capacitors, resistors, diodes, and transistors on a circuit board make up the Video portion of the TV. One or more of these electronic parts are going bad or totally defective. The only solution is a replacement circuit board. Do not waste your money on repairing a circuit board. If you cannot obtain a replacement circuit board, then the Road-star is now a Road Accor.
Dec 22, 2013 | Roadstar LCD7310 7 in. Portable TV
Where to get manual
Hello
Get into this site where you can download the manual in pdf format.
www.blackboxvideo.com/Roadstar%20Monitor.htm
May 16, 2011 | Roadstar LCD7310 7 in. Portable TV
Tamil nadu free ctv remote service mode
service mode tv Audio Ton CTV 5502 Service Mode
Audio Ton CTV 5502
10.3 90° MONO CTV Service Mode;
Press UP & DOWN buttons together on tv's
local control and then switch on.
Jan 07, 2011 | Televison & Video
Tunes in to channels but just craclkling sounds
make sure your sound setup is correct for your country does not auto change when you save the tuned channel
Oct 11, 2010 | Roadstar LCD7310 7 in. Portable TV
Tune T.V. without remote
Apr 10, 2009 | Televison & Video
Need remote for sylavania tv model srt 2113
Mar 10, 2009 | Zenith ZEN450 Remote Control
Digital signal
Most of the small (5") TV's do not receive digital, especially if they are more that a few years old.
Jul 15, 2008 | Spectra Logic 5-CTV 5 in. Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
