Question about Cell Phones
I can't connect to internet via bluetooth mobile phone to my computer
    Problem Solver:
  • 14 Answers
Most, if not all, cell phones cannot use internet from an internet connected laptop or desktop.
Posted on Mar 14, 2011
Internet connectivity with pc via blue tooth on e72
go to connection settings on ur mobile go to bluetooth try to change if ur phone hs provisions for 'use phone as moderm' bt u can easily use internet if u hav a nokia pc suit and a usb cable.! Pliz let me know if dis ws helpful..
Jul 12, 2012 | Cell Phones
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
Can i use my mobile as internet modem via bluetooth (sony ericsson k750i) if i can then how????
if you have mobile internet, in the windows manager for the bluetooth- you would have to enable tethering on the phone (varies by provider!), then setup the device as a network connection in your bluetooth manager.
Jan 09, 2011 | Cell Phones
How to download theme via bluetooth
you can send theme by selecting it and then selecting send through bluetooth. in case the theme is copyrighted you won't be able to send the theme. Bluetooth has limitation of 15 meters hence you cannot connect to internet directly via bluetooth you have to use gprs alongwith bluetooth to connect to internet. you cannot browse others pc or mobile via your mobile hence there is no question of downloading. but you can send themes from others mobile via bluetooth to yours.
Dec 27, 2010 | Sony Ericsson Cell Phones
Connect phone with pc via bluetooth
buy a bluetooth device for pc then install it to your pc after success full installation you can connect now from phone to pc.
Jan 01, 2010 | Cell Phones
How to connect samsung e251 to pc as a internet modem bluetooth
u need to purchase bluetooth doggle nd install software of bluetooth in pc then connect it ur work is done...
Jun 03, 2009 | Samsung SGH-E251 Mobile Phone - Black
Want to connet internet on pc via mobile set 66oo
with help of a bluetooth device you can connecet your pc with your nok.6600 mobile phone, because their is no usb port connection available in your mobile fone.
thanking you
rajiv kumar 9811461147
Mar 28, 2009 | Nokia 6600
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
SE w810 internet connection VIA bluetooth to computer
i want to know that how is speed to connect internet via bluetooth in w810i Sony Ericsson Walkman phone
Jun 28, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
