Question about Dimplex DS5598 Mid-Size Heater
The bulb was out so I replaced it but the new one is not lighting up,I can hear the motor going for the flame effect but I hav'nt got any light,have tried 3 bulbs,what shall I do next?
    Brigadier General:
  • 4,736 Answers
Well, Shirley, you have quite a mystery here. I suspect that the flame affect circuit may have cut out. Turn the Master ON/OFF switch to OFF and unplug the unit for 12 to 15 minutes. Doing this will give he unit a chance to reset itself. If that doesn't solve your problem contact Dimplex USA, Technical Service 888-346-7539 for further advice.
Posted on Mar 14, 2011
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
Flame effect dimmed on my dimplex stockbridge stove
You most likely have a couple light bulbs burned out. Refer to your owner's manual on how to access the bulb area, and replace with the appropriate watt bulbs. Most Dimplex stoves use standard incandescent 60w bulbs, a few use halogen. This is often annual maintenance.
If you can't find your manual, you can request one to be emailed to you from Dimplex, their service line is:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Dec 18, 2012 | Heating & Cooling
Motor running but no flicker effect shaft drive
If you check your owners manual it should tell you how to change bulbs etc. Are you not seeing light, or light comes on but no flicker? If you can reply with model number on your unit, perhaps we can guide you to diagnosis and repair easier.
Sep 21, 2011 | Dimplex Compact Electric Flame Stove...
Light and flame effect not coming on dimplex springborne electric stove.
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
The fireplace is brand new. When the store owner delivered it, it instantly started making a "noise" like there was a part loose. It hasn't gotten any better. Help!
If it's an Electric Fireplace, what you hear is the flame effect rod that's rotating, when you have the flames ON. It's probably out of place from shipping. If you have your Owners Manual, it will tell you how to access the light bulbs, which will give you access to the rod.
Hope this helps solve the problem.
Mar 20, 2011 | Heating & Cooling
Charmglow electric fireplace . no light for flame effect
the fan is working. I do not have the flame effect fixed. I find this web site difficult to get any help from.... seems to go around in a circle. Just tell me if it can be fixed.. I want to know about the bulb (?) or whatever makes the flame effect. Nothing seems to be able to take apart , if not do you have a website I can get to for a new one.....thanks....
Mar 25, 2009 | Fire Sense Georgetown Electric Fireplace
Dimplex DS5598 Mid-Size Heater Logo
159 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
