Question about Dimplex Compact Electric Flame Stove Heater
I have a dimplex heater, the fake fire type and I need to replace the cable 13amp plug and new three core cable brown blue and earth, in the back of the fire there is a red cable attached to a post with two pins do I put the brown and blue on to these pin as I assume these would be the live plug
    Brigadier General:
  • 4,736 Answers
Contact Dimplex USA, Technical Service at 888-346-7539 for a wiring diagram.
Posted on Mar 14, 2011
Wiring a d2 eberspacher diesel night heater up
how much it coast black & decker Heater product model no . or07d
thank you
Dec 22, 2013 | Heating & Cooling
Powercord replacement
hi kim you need to get three new conectors and at least 13amp three core lead just wire up exactly as it is now at top just under the lid they are all pretty much same check you dont have any fluff around heater good idear with top off give it hoover out
Apr 15, 2013 | Hotpoint Dryers
Can i use a normal 13amp plug on a dimplex plx1500 panel heater
Probably not the best idea. It may overheat when the heater is running at the high setting. Best to use a 15A rated cord and plug.
Nov 01, 2011 | Dimplex Compact Electric Flame Stove...
I have installed a garden outhouse which has come with a 3kw heater in the roof and has a 3 wire cable hanging from it. I have an RCD external socket to which I've connected a 10m re-enforced 3 wire...
The switch is probably a single pole switch and just switches the incoming live to the output, in your case the live from the RCD to the outgoing live of the heater. The 2 earths can be connected together and 2 neutrals. When you mention the RCD external socket I presume the cable to the outhouse is fitted with a three pin UK plug so check the rating of the I66 switch to ensure it can cope with the 13 amp current which can flow.
A double pole switch would be preferable. This provides total isolation and switches off the incoming live and neutral of the cable from the RCD. This is safer because if anyone ever rewired the plug at the RCD and mistakenly reversed live and neutral, a correctly wired single pole switch in the outhouse wouldn't switch off the live and this would be a hazardous situation, especially since the heater is in an outhouse which could be damp.
Jul 22, 2011 | Garden
I need to change the bulb in a dimplex brayford electric fire, how do I get the fake coal plastic off.
The plastic ember bed lifts out with a little effort. To assist you, I have included a link to your Bradford model Owners manual that you can download and print for future reference.
http://www.dimplex.com/customer_support/technical_and_troubleshooting?docsearch=GDS26-BW1052&type=&dlang=
Dave, I hope this helps you.
Apr 29, 2011 | Dimplex Compact Electric Flame Stove...
I have a three way plug that needs wiring. the cable has two wires a brown and a blue. with the earth wire at bottom is the blue wire on the left side or the right side
Earth on the bottom, the neutral (blue) will be on your right. The live (brown) will be on your left.
NB: Its not a big issue though if you swap the sides as the current that you are dealing with is alternating. If by mistake you swap the wires, you appliance will still work.
Mar 26, 2011 | Electrical Supplies
I have a protable DVD video player and the plug is gone on it where can i get another one
Is it the plug which goes into the mains ?
If yes then just go to the shop and buy another 13amp plug and connect the BROWN WIRE TO TERMINAL (L)
THE BLUE WIRE TO TERMINAL (N OR NEUTRAL)
AND THE GREEN/YELLOW WIRE TO THE CENTER PIN (E OR EARTH)
Mar 26, 2010 | RCA Televison & Video
Got a numatic henry (green colour) There is a loose wire in plug, but can't open plug to fix. how do i? Thankyou
Hi.
Very simple this one.
The plug is molded type this kind of plug is sealed so you cant make any repairs internally other than change the fuse.
You will need to cut plug off & fit A new 13amp plug.
There are only 2 wires to reconect to new plug these are
BROWN to L
BLUE to N.
& thats it simple.
Aug 01, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Wiring diagram
In the UK, to connect to the connection block of a fixed integrated oven in a Kitchen, you must be a Part P Registered electrician. Such an electrician will issue a Minor Works Certificate for this work on completion - otherwise they are not Registered!
Be aware that if the work is not done under Part P and a fire occurs, etc your insurance company are entitled to REFUSE to pay out for the damage including any consequential damage to neighbours property or for loss of life!!
The block has three terminals and the Live, Neutral and Earth are indicated by marks stamped on the metal back of the cooker (if a CE product).
L = Live and takes the Brown covered wire
N = Neutral and takes the Blue covered wire
52080c4.gifor E = Earth (CPC) and takes the green/yellow covered.
If the cable has an uncovered copper third wire or is coloured Red/Black it should be replaced from the connection accessory on the wall behind the cooker with a heat resistant 3-core Butyl cable of sufficient size to cope with the load of the oven.
If you let me know the rating of the oven (label on door) in amps or watts, I'll tell you what size of cable you need.
Apr 13, 2008 | Hotpoint RB526 Electric Kitchen Range
Dimplex Compact Electric Flame Stove Heater Logo
219 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
