HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the orange and green light is on, then the scanner bulb warming up is lighting up, the bulb goes on and moves 1 inch, the orange light is flashing, the green light is going out, now can i do nothing. Please help me.
  • creative1322 Mar 16, 2011
    How can I update the 3330 ?
    The site from HP says that the 3330 bust be ready, that is imposseble.
    HELP
  • 1,915 Answers
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Posted on Mar 14, 2011
  • 6 more comments
  • creative1322 Mar 14, 2011
    The bulb is looking bright.
    How is the correct output level controlled.
    Can i contro; enything ?
  • Mark Schmit
    Mark Schmit Mar 14, 2011
    In some cases users have been able to clean the mirror in the scanner to get better reflection. This is done by removing the small piece of top glass that the ADF using for scanning. You will have to inch the scanner head back by pulling on the belt. Once you have the scanner back in the ADF scan position you will see that there is a mirror in a slot behind the scanner bulb. Use a flashlight to see how dirty the mirror is. If dirty, use a Q-tip and alcohol to clean the mirror. Reassembly the glass, turn printer back on and you should now have a machine that will come to ready.
    I have cleaned the mirrors and the lens.
    Now I have the error message 79, switch off - switch on.
    What now ?
  • Mark Schmit
    The 79 error is a communication error. I would turn off the machine, unplug any usb or network cables attached and then restart. Does the scanner initialize when you turn it on?
  • creative1322 Mar 15, 2011
    Switching the power of and on do not solve the problem.
    The scanner is initialize when I turn it on.
    Can I replace the mirrors wrong, I have all the mirrors out of the place and cleaned them.
    Then I put them back, but I had not sign't the mirrors. I now wat the mirror site is.
  • Mark Schmit
    Mark Schmit Mar 15, 2011
    Removing the mirrors was not required to clean them and it is possible you have disturbed the alignment of the optical system. The service manual states that a 79 error may be cured by performing a firmware upgrade so that is what I would try next.
  • creative1322 Mar 17, 2011
    I cannot upgrade the 3330, the site off HP gives a note that the machine must be ready.
    And that's imposseble, because off the error.
    How can I do it right.
  • Mark Schmit
    Mark Schmit Mar 18, 2011
    You may not have to have the unit in ready mode. While that is recommended, often these machines will update the firmware without that condition being met.
  • 5 Answers
Here's how to clean the mirrors if it's a scanner problem ie if the scanner seems to be 'stuck' & doesn't respond to being reset
https://www.youtube.com/watch?v=lqG_nmi3vC4
Posted on Jan 24, 2015
  • 1,684 Answers
The "scanner warm up" issue is usually caused by dirty scanner optics. Over time the mirrors in the scanner with collect dust which reduces the image and light levels, this happens even faster in a smoking environment. When the buildup gets to level that blocks to much light you get the error. To correct the error you will need to disassemble the scanner assembly and wipe down the mirrors. Here is a link to a step by step dis-assembly guide that should help you correct the problem.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Posted on Apr 24, 2013
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
Cant print. says printer is offline, printer says scanner bulb is warmimg up. im using a mac
Your issue is caused by dust in the scanner optics. Here is a link to a web page with instructions on cleaning the optics and clearing the error.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 21, 2011 | HP LaserJet 3330 All-In-One Printer
Scanner bulb warming up keeps cycling, seems like the scanner is not working and can not print or copy. Sounds like the movement across the scanner doesn't happen.
Optical scanner assembly faulty, its avil replace it if not open the unit gently remove the cover clean reflecting mirroes with ears buds to aviod scratches, refix and try.. best of luck
Sep 08, 2011 | HP LaserJet 3330 All-In-One Printer
My scanner screen says that the scanner bulb is warming up,but nothing happens. Also my cancel light continually flashes. What could be the cause of this?
Scanner Bulb Error Message
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpl12028&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=66366
ISSUE:
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner's inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1.
Remove and replace the power cord from the unit.
2.
Wait approximately 35 seconds for the scanning assembly to "walk out" and then quickly remove the plug again.
3.
Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4.
Replace the plug and let the product fully finish the boot cycle.
If this does not resolve the issue or the issue returns, upgrading the product firmware may help. The firmware upgrade can be found at the HP Web site Downloads, Drivers, and Notifications page .
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP LaserJet 3330 All-In-One Printer
Scanner bulb warnning
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 MFP
I have that oranage triangle light blinking as warm up message continues I also had power loss I have taken the plug out and will wait a while and try again. I still get now scanner errors using ubuntu..
May 16, 2009 | HP LaserJet 3330 All-In-One Printer
Service tech seeks service manual in .pdf for hp laserjet 3330
Any HP printer. All parts diagrams:
http://partsurfer.hp.com/cgi-bin/spi/main
Apr 02, 2009 | HP LaserJet 3330 All-In-One Printer
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
2,379 people viewed this question
k24674
jasbo
jasbo
