Question about Kitchen Ranges
I have a berkel meat slicer which the blade wobbles on ,
Remove cover plate, then unscrew knife bolts, juices and meats have been lodged behind knife and pully that holds the knife, once knife is removed clean back of knife and front of pully face, becareful not to use too much water and ruin the bearings, then install knife before tighting screws spin blade with fingers to see that you have reached alginment,
Posted on Jun 06, 2013
  • Kitchen Ranges Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Most models have a bearing, washer and spacer that are support the knife/blade in the head housing. The parts are cheap and not to difficult to change.
Parts catalogs can be loacted using this link:
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/Forms/ViewAllPartsCatalogs.aspx
You can use the following link to locate a distributor near you:
http://www.berkelequipment.com/Berkel/Service/
Without a model number I used the 823-827 series models as a reference here:
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/F43190.pdf
Thanks for choosing FixYa,
Kelly
Posted on Mar 14, 2011
Meat slicer blade is wobbling
sometimes the blade doesn't go in quite straight loosen ti and see if it will reset flat not knowing make nor model cannot look for manuel
Feb 01, 2015 | Kitchen Appliances - Others
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Can't sharpen blade
1 of 2 problem exist, you need new stones, or the depth of your sharpener needs to be lowered to compensate for blade wear
Mar 27, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Meat slicer blade won't turn
many of them have nylon gears that the teeth strip off of .
Mar 19, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
My slider arm wont move
Hi Are you talking about the meat pusher or the arm that you push on to push the meat though the blade ?
Sep 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Do not have model #...older slicer. need to remove blade to clean behind
there is a thru bolt on the left side of the slicer if you are facing it to use it, that holds the plate on, unscrew it, its usually red
Sep 07, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
What tool do i need to remove the blade from my Berkel 827A?
Just a screw driver, but first remove the thru bolt holding the blade cover, its on the left side opposite blade its red, take it off then you will see the 4 screws, ez
Jul 13, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
To sharpen the blade of my meat slicer
The stone that sharpens the back bevel is used for more time, but use grind for minimal amount of time, 30-40 seconds sounds extreme to me. The stone for the top surface of the blade is only pressed briefly to remove the slight burrs from sharpening on the back side of the blade.
Oct 09, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
How old do you have to be to clean a meat slicer in the uk
Old enough to know that you unplug it before you work on the blade!
Sep 19, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Ranges Logo
329 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
