Question about Microsoft Xbox 360 Console
When I turn on my jtag all I get is the middle green light. No picture, no sound.
  • jehky25 Mar 14, 2011
    When I turn on my 360 it doesn't boot. The middle green light comes on but I can't get any picture. xell will not come up either when I turn it on with the eject button. Also, the controller will noy sync up. I don't know too much about jtag so any advice will help
    Genius:
  • 1,622 Answers
The major cause of this types of problem is the power circuits board, this is as a result of dry soldering or short circuit.
All you need to do is open the console with the right set of screwdriver like the Phillips model types of screwdrivers.Resolder the circuits, and clean the power supply circuit board with a methylated spirit and couple back. If otherwise then the power supply board is bad . You can replaced for anew power supply from ebay.com or shopjimmy.com
Hope this will help in solving the problem...
Posted on Mar 14, 2011
  • 661 Answers
Don't know if this applies in your case, but i had an elite (non-JTAG) that did the same thing. I turned it off and BOOM, a few hours later I got E74
  • 2 more comments
  • Eddie Chen Mar 14, 2011
    BUT it sounds like you may have jacked up your console while JTAGing. One of the boot sequence routines might be failing a system check, but for some reason isn't triggering an error message. Try flushing ALL of the chips on the board with Isopropyl, and letting it dry for at least 10 minutes, bake it in the oven at 80 degrees celsius for about 8 hours, then reflow all the chips. that should at the very least get you an error message.
    Also, check for damaged components, scratched traces, etc.
    Wait, did you JTAG this? or did someone else?
    and why did you say this wasn't helpful? I wouldn't have answered it in the way that i did if you had given me the info that you did earlier
When I power up my router I get 5 lights , nothing for a power light . Should there be a light on for that ? How many lights should be on total ?
It sounds like a bad flash attempt has bricked the unit (made it as useful as a brick)
It can be revived, but you need a copy of the original firmware and a piece of hardware called a JTAG to flash the nvram in the unit and revive it.
If you google linksys jtag ebay you can usually find this hardware for under $10.
Some computer stores will also do this for you for a nominal fee.
Here's a great little video of the process.
Best of luck!
Mar 21, 2011 | Linksys Wireless-G Broadband Router
WON'T TURN ON
Ur controller board it dead,the one in the middle bottom of LCD screen.It a small square board.Replaced this board should have sound and picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Controller board for the replacement.
Apr 13, 2010 | RCA L32HD31 32 in. LCD HDTV
TV tries to power up but can't
bad lamp, yes it will not have no sound,
Jun 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
No picture or sound on tv
look inside middle of board is there 2 green leds on if there isnt take back off and see which ones out
Nov 09, 2008 | Hitachi 53UWX10B 53" Rear Projection...
RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Aug 24, 2008 | RCA F32650 32" TV
No picture but has blue green and red light down middle and sound
Most likely a blown Vertical deflection output IC. In most (but not all) Panasonic, the vertical IC is an AN55XX.
Repairs should be fairly easy with basic knowledge of electronic circuitry and components and a little soldering. I would expect the IC to be readily available at any electronics part store. Should you be uncomfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 28, 2008 | Panasonic PT-51HX43 51" Rear Projection...
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Microsoft Xbox 360 Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
