Question about HP Pavilion dv5-1138nr Notebook
My laptop is Hp Pavilion and my battery doesn't charge though it shows that the power is plugged in.It's at 38% and when power is disconnect ,the laptop goes off.What do i do?
  • HP Master
  • 1,719 Answers
It clearly indicates that the battery of your laptop has deteriorated and cannot hold enough charge to run the system without AC Adaptor. So, the battery is supposed to be replaced with a new one. I suggest that you buy a new genuine battery (not any replacement), as genuine battery would last longer and serve you best.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Posted on Mar 14, 2011
  • 28 Answers
How long do you leave it to charge? What is the battery life of the battery? How old is it? If the battery is old it's going bad, which means you may need to buy a new battery. You can look at e-bay or some computer sites to find a cheap battery replacement. Hope this helps
  • 784 Answers
Motherboard error, loading the chip is faulty.
  • Diether Masing
    Diether Masing Mar 14, 2011
    itself can not do anything about it can only lead to repairs.
    Problem Solver:
  • 30 Answers
Change the battery.
  • 22 Answers
Sadly it seems you have a dead battery on your hands. If it's still under warranty i would advise to activate it and get a new one. If not, you can find cheap batteries on your local dealer (compatible ones may be cheaper but may void your warranty. If possible always use original parts).
Hope i was of any help.
Pcsimples
  • 24 Answers
Unfortunately laptop batteries to tend to die after a time with repeated re-charging.
While it may seem like a strange suggestion, it has previously been suggested and i've had luck with the 'freezer method'
Theres a little more info and discussion on it here: http://lifehacker.com/#!308225/revive-a-dead-laptop-battery-in-the-freezer
However simply try putting it in a ziploc bag and putting it in the freezer for up to 24 hours. It won't be as good as new but might perform better.
Alternatively i think the only other option is to buy a new one. you can find many options (depending on where you live) by googling your laptop model number & battery.
hope this helps.
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
My laptop is saying the battery is low but I have it plugged in to power. What is wrong? It is only 5 months old.
Bad power supply, your power supply has gone bad and is not charging your unit anymore, even though it may show the charge light is on, the is because there is such a small amount of current going through the system that the icon shows charging, but not enough to charge the battery
May 25, 2010 | HP Pavilion dv9000z Notebook
HP Laptop Battery Problem
I had a similar problems and I had my batter replace by Hp free of charge. Most like your batter could be damage internally or it could be a motherboard problem.
I suggest you visit this HP link http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Jul 03, 2009 | HP Pavilion dv6000z Notebook
I have an hp pavilion dv9350ea. Over a couple of years the battery became defective and I installed a new one. It showed 30% charge. I disconnected the charger to discharge the battery before re-charging...
I have to agree that the battery is defective or maybe it is NOT the correct one for your system, although it may be similar.
Did you buy the battery direct from HP a third party?
The AC adapter charger could be defective as well, maybe the defective battery ruined the charger.
I hope this helps.
Good Luck.
Mar 10, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion ZD8000 - Battery
i have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Nov 28, 2008 | HP Pavilion zd8000 Notebook
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv5-1138nr Notebook Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
