Question about HP Office Equipment & Supplies
HELLO. HP SCANJET 5200C ON WIN XP STOPS WORKING JUST AFTER STARTING. USING USB. TRIED RE-INSTALLING SEVERAL TIMES. IS IT BETTER TO USE PARALLEL CONNECTION? WB
    Guru:
  • 1,049 Answers
Yes, if the USB is giving you consistent issues then parallel is a more straight forward method of access as it does not create a virtual port. Might slow your scans down though.
Posted on Aug 01, 2008
My HP ScanJet 5200C doesn't work with my new HP computer. Do I have to install a driver, or...
Access the manufacturer's web-site: http://support.hp.com
and enter '5200C' and do the search.
Select the device-drivers for the Operating System that is installed on your new HP computer.
Download & install.
Sep 23, 2010 | HP Scanjet 5200c Flatbed Scanner
HP 5200c scanjet - get black page
yes, your fluorescent bulb is burned out and you cannot buy a spare. Sorry
Oct 11, 2009 | HP Scanjet 5200c Flatbed Scanner
My scanner is hpscanjet 3200c & my pc consederit umax astra 1220p
HP OEMed the ScanJet 3200C from UMAX. It's a Astra 1220P UMAX does not support this scanner anymore also HP does not but if you look around you will find file sj648en.exe from HP. This might work on your system, it's for upto Win XP.  I have been trying to get a USB to parallel to work with this scanner, so far so bad many many hours.
Jan 23, 2009 | Umax Astra 1220P Flatbed Scanner
Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Dec 22, 2008 | HP ScanJet 3200C Flatbed Scanner
Driver HP Scanjet 3800
U CAN EASILY FIND THE DRIVERS AT FOLLOWING SITES-
www.driversplanet.com
www.download.com
www.drivers.com
etc.
& please rate me nice too.
Jun 23, 2008 | Microsoft Windows Vista Ultimate Edition
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
Software and hookup problems with dell vostro 400
Add a pci parallel card such as this to your vostro. www.tigerdirect.com/applications/category/category_slc.asp?CatId=512
This will enable you to connect your scanner. Tiger direct will give you closeups of the connections on the interface card so you can check you have the right one.
Mar 22, 2008 | HP Scanjet 5200c Flatbed Scanner
Hp scanjet 5200c does not power on
check your adapter or power cable first.
Mar 20, 2008 | Office Equipment & Supplies
System shuts down and mouse stops working
Try doing a BIOS update on the sys if it doesnt work out uninstall the drivers from both the sys and try to use the unit as a plug and play device the sys should automatically detect the new hard ware found wizard and install it using that it should fix the issue
Feb 19, 2008 | HP Scanjet 4370
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
