Question about Car Audio & Video
Recently my sub has stopped woking due to not having enough power i have checked all the fuses and tested the amount of volts running through and found that when the head unit was on the power was decreasing from the sub i think it is something to do with the remote cable but not sure hope you can help thanks
  • 635 Answers
The remote cable only brings a low current 12v trigger supply to turn on the amplifier,because it is remotely mounted with out any on / off switch or its own . Use heavy cables for the Power + and power - of the sub woofer. And make sure the + red wire of the Sub module is directly connected to the battery terminals of the car and the - black wire is bolted well to the body of the car ( make sure the nut is not painted or insulated ).
Posted on Mar 14, 2011
I own a 1999 pontiac grand am gt. I was hooking an amp up to a set of subs and got everything to work. When I finished and put my dash back together it all stopped working. My head unite (alpine cdm-7871)...
Get a multimeter cheap on ebay ,and test the red (positive wire from the radio with the key tuned to on position. should read 12v.. Key off should have 0 volts. Then check the yellow wire, should read 12 volts continuous with the car on or off. If you don't get a reading from yellow wire, you can run it from the battery into the car. Red, you would have to run from the fuse box and should only have electricity with acc on (key in ignition) If both red and yellow wires read 12v. you could have grounding issues. Use the black wire from the head unit and wire it to metal. These are the only 3 wires you have to worry about.
Sep 05, 2013 | Car Audio & Video
System starts hitting and my clip light comes on on my amp and all the bass stops
4 quick checks. try lowering the gain on your amplifier. check if your sub or subs are not making the amplifier run lower than 2 OHM. check if the power cable is the right Gauge(4 Gauge) and the fuse is large enough for the amplifier. It should be slightly more than the fuse rating of the amplifier. check to see if your ground is secured properly to the chassis. dreamsystems
Feb 16, 2011 | Infinity Reference 611a Car Audio...
I have just recently replaced the battery on my MR2 and the car was driving fine and after a week I noticed that the voltage meter was reading almost half way rather than the normal three quarters. I kept...
retest your alternator/charging system. Either alternator or voltage regulator is bad. If you have a volt meter/or access to one - easy test - start car and test voltage at battery - it should be 12.6 - 14.8 volts w/car running anything less you have alt/volt reg problem
Jan 05, 2011 | 1991 Toyota MR2
My computer went blank when turning it on
1) Computer isn't working, due to the Processor isn't working, due to a bad Power Supply.
Weak voltage power rail.
Enough power perhaps to light LED lights, and maybe spin fans, but not enough power to turn the Processor on.
Computer Power Supply's are rated in Wattage.
Volts times Amperes = Watts.
(Average computer power supply in a fairly new computer, is rated at around 300 Watts)
A) ALL of the LED lights combined, use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts.
C) A typical Processor may use 51 to 125 Watts.
Depends on what Processor it is.
Power Supply with a weak voltage power rail, can have enough power to light LED lights, spin fans, but not enough to turn the Processor on.
Solution?
Test the voltages of the Power Supply,
Or, use a KNOWN to be good Power Supply, that has the correct amount of power cables, the right kind of power cables, the correct size, and shape of the case, and enough Wattage, for a test unit..
A bad Power Supply is one of the leading causes of computer failure.
Sep 19, 2010 | Computers & Internet
Electrical system?
FIRST THING TO CHECK. BATTERY VOLTAGE IT SHOULD BE 12.5 VOLTS.IF NOT HAVE IT CHARGED AND TESTED.IF CHARGED AND GOOD. CHECK ALTERNATOR ALTERNATOR OUT PUT.IT SHOULD BE 13.5 TO 14.5 VOLTS WITH CAR RUNNING IF NOT.HAVE ALTERNATOR REMOVE AND TESTED MAKE SURE.BECAUSE IT COULD BE A BLOWED FUSE OR FUSE LINK.BELT SLIPPING AND ALTERNATOR WIRES BROKEN OR MAKING BAD CONNECTION.DUE TO RADIO LOCK OUT FEATURES .DONT FORGET TO TURN OFF RADIO BEFORE REMOVING THE NEGATIVE BATTERY CABLE.
Aug 10, 2009 | 2003 Saturn VUE
The sunroof on a scion tc 2005
My best bet is its your Sliding roof drive gear sub-assembly. I would also check your sliding roof control switch and you wiring harness. In fact i would check those those first since they are the fastest to check and then that only leaves your sub assembly. you will need to remove your headliner to test everything. And you will need a volt meter that you can get for a couple bucks at most electrical stores. use your volt meter to make sure your getting the same amount of to power to your switch as your getting just past it when it is closed. then test the wiring closest to your motor with the switch closed and there a very minimal amount of volts lost. If everything checks out i would go with the sub assembly. Hope this helps.
Jul 09, 2009 | 2009 Scion tC
My Crunch Amp In My Blazer Has Stopped Working! Please Help!
NO if your amp is good any battery will turn it on. changing batterys does not require a reprogram?. id say amp is damaged from being wet. test to see if power is going in and out if nothing out bad amp..
Jun 01, 2009 | Crunch GP1100.2 GroundPounder 1100W 1/2...
Amp just abruptly stopped working (Pioneer GM-5300T)
Apart from the external DC power fuse (I hope you have one in-line), the majority of in-car amps have 2 mini fuses inside the unit to protect the output MOSFETs from overloading due to incorrect speaker connections, ie, if the output impedence is rated at 4ohms, anything less than that is considered to be a short circuit, and will overload the MOSFETs. After performing the tests suggested by KaeZoo, open the unit and look for printed markings on the circuit board, something like F1, F2, the fuses may not look like conventional fuses.
Jun 11, 2007 | Pioneer GM-5300T Car Audio Amplifier
Protect light flashing/ticking
this problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Oct 08, 2006 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
