Question about Polycom VSX 7000 Video Conference
When we have 3 connections we don't have problem we have 3 images but when arrives the 3rd connection, one of the 4 screens become blue
  • 3 Answers
HI
You have 3 connections with your site???
Posted on Apr 28, 2011
Data imaging solution on c7000pro bizhub
7A00 Description Failed to arrive home
• Error of the imaging carriage home sensor. • Error of the carriage motor. Causes • Controller board (CTLB) • Imaging carriage home sensor (PS15) • Flatbed motor (M4) Remedy 1 Turn OFF/ON the main power switch. 2 Check CTLB for proper connection and correct as necessary. 3 Check PS15 and M4 for proper connection and correct as necessary. 4 Replace Flatbed unit. 5 Replace ADF unit. 6 Replace CTLB.
Dec 10, 2014 | Konica Minolta bizhub Office Equipment &...
Turn on at power button no rotating "hour-glass" ; screen becomes blue then displays vertical multi-coloured stripes over whole screen. Sound From tele program. No reaction to remote cntl
there is a problem with the connection
asthe screen becomes blue it mean that there is nothing to project
maybe the connecter is faulty
Sep 15, 2008 | Televison & Video
My dad has a fuji finepix a500 camera. lately, he's noticed that some of the images on the screen are showing instead as a blue screen with "read error". how can we fix this/what has...
What happens on your camera is related to the pc modifying the image file, hence the camera can't read it as they use different formats to write and read the images.
Can you see the pictures stored on your father's camera on the PC? Because if that's not possible, then the camera has an internal problem and you might have to consider taking it to a repair shop, or even consider buying a new one.
Jul 12, 2011 | Cameras
When we have 3 connections, we don't have problem, but we arrives the 4th connection, one of the others camera become blue
is it same location or camera that turns blue
have you tried lowering the speed of call ( this will help see if it is bandwidth issue) like you dont have enough
have you tried making call by calling out only 2 sites per unit (not using one site to originate all end points)
also are all CODECs using same firmware revision
give me more details and i can help more
speed of calls, network being used, etc
Mar 14, 2011 | Polycom VSX 7000 Video Conference
Cannot get the decora 4 way light switch to work - 2 of the 3 switches work but cannot get the 3rd to work. Replacing regular toggle switches which all worked but wiring different for decora switches.
Decora 3-way and 4-way switches do not wire differently than toggle-type switches.
Instructions below are tedious but will accurately guide you to solution.
Let's break down the problem starting with 3-ways.
1) Start with 3-way switches:
Old 3-way switch has 2 brass screws and 1 dark screw
New decora has same color screws.
Wire that went to dark screw on old device must attach to dark screw on decora device.
Other two wires can attach to either brass screw.
Wires that attach to brass screws are travelers ... these wires travel to the 4-way switch.
So there are 2 traveler wires at each 3-way switch.
2) Let's test if 3-way switches are wired correctly by taking 4-way switch out of equation.
We will resolve problem with 4-way switch after 3-ways are correct.
There are 4 wires at the 4-way switch.
These are the 2 traveler wires that arrive from each 3-way switch.
At the 4-way switch, 2 wires arrive in one cable, and 2 wires arrive from another cable.
To say it differently, there are 2 wires from cable1 and 2 wires from cable2.
Connect 1 wire from cable1 to 1 wire from cable2 with a wire nut
Now connect the 2nd wire from cable1 to 2nd wire from cable2 with another wire nut.
So now the traveler wires are connected, and the 4 way switch is out of equation.
Turn on power, and click 3-way switches to see if both switches turn lights on-off in all positions.
Do your 3-way switches work correctly?
3) If 3-ways are not correct, then you have wrong wire connected to dark screw.
First thing to check is if you can identify traveler wire colors by looking at wires at 4-way switch.
Remember, traveler wires at 4-way switch go back to 3-way switch and connect to brass screws on 3-way switch.
4) If you cannot tell traveler wires by looking at 4-way switch, then you can try different combinations until both 3-way switches work.
Or you can test: disconnect wires from one of the 3-way switches. Separate 3 wires for testing. Move other 3-way switch to down position. Turn on power. Test each wire to bare ground wire. Mark wire that lights up. Now move other 3-way to up position. Test each wire to bare ground wire. If same wire lights up each test, then that wire goes to dark screw. If different wire lights up, then mark that wire. The two marked wires are travelers, and they connect to brass screws. Other wire connects to dark screw. Repeat identical test for other 3-way switch.
At this point your 3-way switches will work, if light bubs are not burned out.
5) Last step, the 4 way switch.
Remember from step above, that 2 wires arrive in cable1: These 2 wires connect on one side of 4-way switch. The other 2 wires that arrive in cable2 connect of other side of 4-way switch.
Add a comment if you need more help.
Dec 23, 2010 | Leviton Decora Light Dimmer Switch
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
Mp4 player
connect to a computer.
same thing happened to my chinese mp3 n then when i connected to pc n then it started working after like 30 seconds.
Jun 05, 2008 | Apple iPod nano 3rd Generation
Tomtom - time of arrival
It is possible that you have the TomTom set for "walking routes" or "bicycle routes" or "limited speed." (I have a TomTom One 3rd edition, so if you have a different model the menus/icons may be different, but it's worth a shot.)
Click on the main part of the screen, while on the main navigation screen. Then click on "Change preferences." Then click the blue arrow to scroll to the Preferences 3 of 5 page. Click on "Planning preferences." Choose the planning preferences that you want. Hope this helps...
Nov 11, 2007 | Tomtom ONE GPS Receiver
Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Jul 14, 2007 | Samsung PS42P4AX 42 in. HD-Ready Plasma...
Polycom VSX 7000 Video Conference Logo
71 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
