Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
Batteries are full load, checked the voltage and it is 24 including at the plug in the bow but after 5,10 minutes of use the power is lost. It seems to me the TM never gets all the power. It worked fine for 1 year until I asked a mechanic to tighten the connection between the TM and the boat as it was loose.
  • Victor Sirbu Mar 14, 2011
    I tested the power at the plug in the bow of the boat and it is the correct 24 V. So, the cables to the bow of the bot seem to be fine. After that, the power cables go into the TM (the part that connects to the bracket).
    What else can I check?
    Brigadier General:
  • 3,513 Answers
Hi
Be careful when using your motor when fishing in thick vegetation. If this wraps around the prop it causes overloads and higher currents. The high currents cause general overheating which affects all parts of the motor. Check for low battery voltages and for loose cable connections that cause resistance and loss of motor power.
1. Check for loose connections in the speed switch and potentiometer.
2. Check for loose connections within the top housing.
3. Check the rotary switch for burning or other visible damage.
4. Check contact continuity or resistance with a multi-meter or short out each speed terminal to verify the switch contacts. If switch is in good condition one or more speed coils may have failed.
Lastly you need the right batteries, the right charging system, the right wiring and the right charging to keep your trolling motor online.
Also check the bellow link for trailer wiring details:-
http://www.fishingandboats.com/wiring-a-boat-trailer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 14, 2011
    President:
  • 2,047 Answers
The symptoms which you experience are as a result of poor wiring or contact to or from the batteries. It is possible that when the mechanic tried to tighten the unit he tampered one of the cables of the unit. Simply get a better mechanic to examine the power connection cables to and from the unit. The problem is as a result of partial contact so should not be too hard to fix all you need is just careful examination.
hope this solution has been helpful?
APC Back-UPS ES500. Battery is new replacement UB1280, and battery has charge and runs fine if unit not plugged in. However, if unit is plugged in to power back-up side outlets in unit don't work.
there are 2 parts of a UPS .
the charge side
and (battery is obvious)
the inverter side.
if the charger fails, all is lost. (are the batteries in backwards?)
if the charger works (volt meter tells you that)
then the inverter is bad. (this unit is not full time UPS , but part time, this means it switches over to inverter at power fail.
(on full time sys. inverter runs full time, like the name states)
the unit, you mean the load right.?
the UPS side plugged into a load. and the load is now dead.
the Backup plugs should work if the mains are hot.
if you kill mains, the inverter will fire off, (hear the squeal?)
and give you 500 watts for some minutes, sucking the batteries dry. (see load run time curves)
I used to do service on HUGE UPS systems, some with 100s of batteries. 3 to 5kw too.
on ours there is a port on the rear , we connect and can
check everything "BEST brand" even charge voltage.
did you look on APC site for special software and connections?
the manual does cover trouble shooting, ever read that?
RTM? start there, its online, for sure.
Oct 03, 2013 | APC Back-UPS® CS 500 UPS System
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I was using it when all the sudden it just quit working. I have had it on charge for two days thinking it could have been the battery. I know the battery is charged, I have checked it. I have power at the...
Hey SCOTT ..
Get a multimeter (to check voltage) Verify you have 24 volts coming to the front plug. Now - VERIFY that you are getting 24 volts to the switch. ..All OK..- Now to check the power switch. Disconnect the two wires on the power switch and CAREFULLY connect them by hand.. now SAFELY see if the prop will turn. If the switch is bad, bypassing it will make the prop spin!
..If the prop still does not work,, keep following the voltage.. For more help, trust these guys!:
http://www.jonestrollingmotor.com/
Jun 12, 2017 | Minn Kota Maxxum 80 Freshwater Bow Mount...
I have a 1996 nssian maxima and i cant seem to start the car. i can start it up twice and then try it again and i wont work. i changed the battery and just yesterday i drove it a few miles and then the car...
I don't think you have a plug wire or spark plug issue. If the starter solenoid is clicking that is an indication of a bad connection somewhere in you starting system. I would check all of the wires in your starting system and make sure they are tight. You may also have a bad starter solenoid. Have your alternator checked fro proper output as well, any auto part store will do this check for free. Also have you battery load tested, just because it is putting out the correct voltage doesnt mean it is putting out enough amperage under load.
Apr 07, 2010 | 1996 Nissan Maxima
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
I have a minn kota 48 AT 12/24 volt bow mount that I run on a two battery 24 volt setup. The trolling motor is on a 3 prong plug into a panel at the front of my boat. That panel has an on/off/on toggle...
use a volt meter and check for voltage at the plug, if none..check in the back near your batterys and locate the circuit breaker and reset it ...basic system = battery-breaker-wires....hope this helps ....GL
Jul 05, 2009 | Boating
Bad control board
If the voltage on your boat's plug drops down to .8v, then the problem is almost certainly in the boat. Trace the wires. You probably have a corroded wire connection somewhere. If there is a fuse in the circuit, check it and it's holder very closely.
Jun 13, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Jan 22, 2009 | Powerware PW3105 700 (103004248-5501)...
    Converting From 12/24 to Starght 24 Volt
    if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
    if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
    connetion as follow:
    positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
    Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
    191 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
