Question about Brother SE-270D Computerized Sewing Machine
Jams up when attempting to sew, making loud noise. Thread mass under fabric when able to cut loose from machine.
  • Brother Master
  • 1,133 Answers
Thread jams underneath usually are caused by top thread tension issues. Things to check:
top tension discs are clean and no thread traces caught in there, tension is set to medium number usually 4 or 5 and that the top thread is running freely from the thread spool, correctly thread through the tension discs, and down to the needle. Lower the pressure foot and pull the thread from just above the needle; it should feel firm resistance if under tension correctly.
As you've had a good jam up, good idea to now remove the bobbin, needle plate and bobbin holder (refer to your manual if you have never done this before) and clean out the hook area well, look for any fine thread remants and brush out any lint etc. Oil the rotary hook area as per your manual. Now reassemble, and rethread everything again checking that the bobbin thread is clicked into the tension spring and that the top thread is through the tension discs correctly.
Also, pop in a new needle, flat shank to the back, then try again.
Good luck with your machine.
Posted on Mar 14, 2011
Get a rats nest when I start sewing
I am not sure, but you can try this:
when the tension of the thread obove is loose, it jams down. Different fabrics call for different tension.
Try tightening it buy screwing colckwise above the needle. Use a piece of fabric to investigate the best tension for your proyect.
Wish you luck.
Dec 15, 2013 | Janome Memory Craft 4800QC
Bobbin always jams, thread bunches up under fabric, auto winding causes a birdsnest of ruined, loose thread and most importantly it won't sew.
Your tension is not set right. The tension setting is usually around 4 and can chang e depending upon the fabric you are using. Hope this helps.
Dec 10, 2013 | Singer 2250 Tradition
I have an Elna xe35, everytime I use it, the thread Jams underneath, how do I stop this?
try changing the needle--normally flat side goes to the back of the machine
also make the needle & thread will work for the fabric being sewed
make sure the bobbin is turned the right way & inserted correctly in the bobbin case
make sure that the thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for loose thread & lint
Apr 02, 2012 | Sewing Machines
Sewing machine motor jams when I sew thick fabric
a part of the computer is malfuctioning, & needs to be checked
try a new needle
rethread the machine using every thread guide
clean under the needle plate & in the bobbin area for loose threads & lint
Mar 19, 2012 | Sewing Machines
The needle thread do not cath the other thread to do the looping anymore? This matter occur after a major fabric jam under the foot. What could be the problem?
The most likely culprit is timing. Severe fabric jams tend to cause slippage of linkage connecting loopers to the drive shaft. The timing will probably need to be adjusted. If you have the service manual (not the owner's manual) and tools you can attempt to make this adjustment yourself. If this is outside of your comfort zone, please take your machine to a qualified sewing machine technician.
May 16, 2011 | Euro-Pro 100-545 Mechanical Sewing Machine
Every few stitches thread gathers and jams on bobbin side of fabric. Why? [the machine is a Singer model 6180]
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Sewing Machines
Bobbin thread
Make sure that you have your thread going through all the proper thread guides when winding your bobbin. It sounds like the bobbin is getting wound with little or no tension and this can make a horrible mess when trying to sew. Take a look at your bobbins and make sure they look nice and tight. If they are too loose and you feel like you are following the thread path properly, just use your finger to tug on the thread a bit during the bobbin winding process to apply some tension and that should help.
Jul 06, 2008 | Brother LS-1217 Mechanical Sewing Machine
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
320 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
