I have cracked screen on my LG 42 Plasma model number is LG 42PC1DA. Is it possible to have the screen replaced and if so how much would i be looking at, Thanks
  • 132 Answers
Call your local authorized LG repair rep.. They would be able to give you an idea of what it is and how much to fix. If it is still under warranty it would be free!
Posted on Mar 14, 2011
I have a Plasma TV LG model # 42PC1DA. We have perfect sound, but no picture. Tried the contrast, tried unplugging for 30 min. What could be the problem and how much might it cost to fix it?
Did you tried diferent sources from where you get the image? For example you could try to connect a video camera, laptop, dvd or any other thing you could hook it up in your TV and check if there is still no picture.
If the screen is burned it costs the same or a bit less than a new one
Good luck
May 06, 2011 | LG 42PC1DA 42 in. Plasma HDTV
The screen on my lg 42pc1da tv is cracked is it cost efective to repair or replace the tv
That's a tough one to answer with constantly changing prices, and different prices in different areas, but in most cases, a plasma screen is more expensive to replace than the entire unit (especially if you move to LCD or another technology).
You'll have to call around your area and see what places quote you for a new TV and what shops will charge to get you a new screen.
Mar 19, 2011 | LG 42PC1DA 42 in. Plasma HDTV
My 42' LG plasma tv model number 42PC1DA-DU monitor is not show but the sound is working. What should I do?
In this case, the defect is in Y-SUS PCB, change it and adjust the voltage that are specified
on sticker attached to plasma module
Feb 25, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Lg Plasma PC1DA no Picture??????
The provided description is typical for failure of a YSUS board, which is in turn quite typical for LG 42PC1DA and a bunch of other makes and models which all share the same internals.
To find out whether it's the YSUS or the ZSUS board that has gone bad look at the following article:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
This is for a different make and model, but has the same core modules that 42PC1DA has.
This article also addresses the case when the TV refuses to come on, which is usually caused by a shorted IPM module on a YSUS board which, however, did not lead to burning the fuse as it normally does.
The failure is actually the same, only the symptom is different.
If the failed board is the YSUS (which is the case most of the times, but not always) then you may want to check
http://blog.coppelltvrepair.com/2011/03/how-to-uninstall-6871qyh053b-and.html
Finally, you may consider the following:
http://blog.coppelltvrepair.com/2011/05/should-i-replace-repair-one-or-both.html
Should you need to have one or both boards serviced you can use the following:
http://www.ebay.com/itm/Sustain-6871QYH053B-LG-42PC1DA-REPAIR-EXCHANGE-/110535815308
Apr 12, 2010 | LG 42PC3D 42 in. Plasma Television
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
Oct 01, 2009 | LG 42PG20 42 in. Plasma HDTV
NEED A BASE FOR PLASMA TV
Manufacturer LGE Part Number 3501900014B Description BOARD ASSEMBLY
Aug 20, 2009 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv
Hello
Check the contrast settings
If you are a Technician than just check the video supply from 150 to 200 volts at all three RGB Cathodes in most of cases there would be dry soldering in others it could be due to failure of supply resistance check base biasing voltages if u can provide more information then I could pin point the fault
Good Luck
Nov 16, 2007 | LG 42PC1DA 42 in. Plasma HDTV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
