Question about KitchenAid Kitchen Ranges
Kitchenaid oven will not turn off - KitchenAid Kitchen Ranges
  • 2 more comments
  • JSMeyer777 Aug 01, 2008
    KitchenAid Model KEBS208DWH8 ... double convection oven ... the top oven, bottom element seems to stay on ... if the oven door is left closed the oven will warm to around 200 degrees F.
    CoolGuy008 ... can I replace the electronic control on my own ... I am very handy with replacing electronic parts (like computer chips) ... what part is likely at fault.
  • JSMeyer777 Aug 11, 2008
    All the answers were incorrect for this problem. The oven has a "Sabbath" mode which will stay on even if the unit is power failed. Somehow, the Sabbath mode was enabled, causing the oven to heat at a constant temperature. Replacing the microprocessor inside the machine would have been a waste of money.
    Genius:
  • 1,011 Answers
Dear sir/madam,
i think the Gear box is broken. The Gear box has two modes, when the motor runs one way it, operates on "agitate" mode where the agetator is moved back and forth. When it runs other way it the entrie drum spins and some hoe safety breaks get engaged when it catches up speed. Then the motor get over heated and there is a safety overheat/load switch in the motor that shuts off the power to the entire machine. So I have yet to figure out why the breaks get engaged.
Thanks
good luck
Posted on Aug 01, 2008
    Genius:
  • 2,035 Answers
There is relay problem in the oven which is not shutting the unit off ,you need to replace the unit...
The control board (called a Central Control Unit, CCU) on your model . You can find this part at repairclinic.com.
Good luck....
    Genius:
  • 3,422 Answers
HI,
The Electric oven control is defective.This problem requires a physical presence of a tech.There are no home remedies.Also let me know if there is any error code flashing.
  • 5 more comments
  • Priya darshan Aug 01, 2008
    You can turn the breaker off and allow it to cool down for few hours.
    In your model i believe it is the MCB(Microcomputer control board)which costs $280.See i strongly recommend you to call the tech and get it done.IT is also difficult to get the service manual online.
    Yes,that's the part..
    Did you find a service manual for that?
    I strongly recommend you to contact repairclinic once and confirm if that's the part because in most of kitchen aid oven it is the CCU.Just call them once.
    Do not buy it right now please give them a call once and confirm if that's the right one.I believe it is the right one but still just confirm with them once.
    And please do not even attempt to repair it without a service manual.If you don't get the manual then a repair tech is highly recommended.
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Used self cleaner on my Kitchenaid oven and now oven doesnt work.... not the household fuse any suggestions
Is it a fan forced oven? Does the fan and the light come on when you turn it on but no heat?
Feb 06, 2011 | KitchenAid Ovens
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
I was cooking in my Kitchenaid oven and the door locked. It will not unlock
We had the same thing happen
Turn the oven breaker off, then let the oven cool completely. Turn breaker on, there will be an error code appear, push and hold the "bake" button for at least one minute until an error message appears, then press the off button.
This reset the latch on our oven
Nov 02, 2009 | KitchenAid Ovens
KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Mar 09, 2009 | KitchenAid Architect® KEBS277S Electric...
Kitchenaid oven
turned off oven. continues to beep F 7
Aug 27, 2008 | KitchenAid Ovens
Kitchen Ranges Logo
251 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
