Washing machine spin dry is too slow. Can handle only 2-3 clothes but if more, it will spin too slow..sometimes doesn't spin at all. Nikai NWM700SPN2 model of washing machine.
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore Washing Machine Model 23912-100
you may have spin tube grease leaking into the clutch causing the clutch to slip during spin and then not getting up to full spin speed. it is common and will require you to replace the clutch. its not an easy job for the do it yourselfer as you need to remove the transmission to get to the clutch.
Posted on Dec 28, 2008
  • 113 Answers
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
j_alcaidinho
  • 107 Answers
SOURCE: My washing machine will not spin clothes dry
You need to check ur pump assembly, there might be something blocking it
Posted on Jan 15, 2010
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
How to more dry after completed washing
A washing machine does not really dry clothes. All it does is that it helps remove most but not all water from the clothes by spinning the clothes at a very high speed and the water comes out because of centrifugal force.
To further dry the clothes, you need to buy a clothes dryer. This machine has a heater inside that actually dries the clothes while keep it spinning at a slow speed.
Usually the company that made your washing machine will also have a dryer in the product portfolio.
Hope that helps
Feb 22, 2015 | Washing Machines
My beko wb 6004 ns doesn't spinning to dry the clothes
the issue is in the timer . have a qualified technician change it with a new one . thanks .
Jun 14, 2013 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Whirlpool LSR7010PQ2 can't spin dry, clothes still wet
If it was spinning slow before the total failure It would be your clutch ,Check your lid switch.
Apr 24, 2009 | Washing Machines
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
